Post new topic Reply to topic  [ 338 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 23  Next
Adeptus Ministorum Orders Militant v1.3
 Post subject: Re: Adeptus Ministorum Orders Militant v1.1
PostPosted: Mon May 03, 2010 2:42 am
zombocom wrote:
BTW I can't really imagine why you wouldn't fully mechanise; you can do it cheap with rhinos and sisters lack ranged fire so aren't much good as garrisons. Maybe repentia or retributors could be ok garrisoned on foot, I guess.
Well, you're right regarding garrisoning. Retributors would be the unit of choice for that.
As for going full mech, I agree, but I love Immolators too much! That and theyre the only transport with an actual ranged gun. Assaults tend to take a lot of planning, and so moving multiple formations in singles or doubles, who dont get a shoot a thing, is one of the biggest wastes I can think of. As part of a double-tap, sure, but I dont retain on every activation and neither do my opponents.
Maybe I'll only use Immolators on Dominions, but naw, every formation must have at least one.
Also, I am not sure the 30-point Repressor is worth 30 points. It isnt as useful as an Immolator. I think 20 points is better, but still costly.
I hope when all is said and done that this list remains something I still want to play. After all, my new Sisters just arrived in the mail and I'll want to get them up and running this week!
PostPosted: Mon May 03, 2010 1:13 pm
Take another look at the repressor stats, it's armed with a Heavy Flamer. Right now it's probably the best tranport option by far; 2 transport spaces, walker and a heavy flamer. The immolator only has a twin heavy flamer, which is still only 15cm just slightly better to hit stat, and better FF, but you have to buy a lot more of them to carry the formation, which makes them a lot more expensive. They'll be going to FF3+ to balance them more.
Of course it'll be expensive to put them all in immolators, much as it's expensive to put all marines in razorbacks. It's a trade-off, I usually take one or two repressors or immolators on a formation and the rest in rhinos. Depends on their role of course though; immolators are probably best on retributors, repressors probably best for repentia.
But yeah, the repressor has a heavy flamer.
PostPosted: Mon May 03, 2010 6:37 pm
Nice. Is v1.2 going to be out soon?
PostPosted: Thu May 06, 2010 8:40 pm
The suggestion has been made to me to have weapon options on the immolator, much as the marine razorback has a weapon option.
A Twin MultiMelta immolator would certainly have a different role to the twin heavy flamer one, while also being a way of including a MM into the list, it being an iconic sisters' weapon.
However, I can certainly see it being worth more than the heavy flamer version.
PostPosted: Thu May 06, 2010 8:50 pm
Would they have the same FF value? Things like Dreadnoughts and Razorbacks typically retain the same CC/FF stats. I guess both could be FF4+ but that makes the MM immolater worth vastly more.
PostPosted: Thu May 06, 2010 9:05 pm
Well, Im of the opinion that 30 points is too much for the Immolator as is, though I havent tried the FF3+ yet. This would be interesting.
PostPosted: Thu May 06, 2010 9:51 pm
No reason they'd have to have the same FF stat.
PostPosted: Thu May 06, 2010 10:37 pm
once you factor in the cost of a rhino, 30 points is effectively 5 points cheaper than a razorback, and I think that's about right. They're deliberately slightly more expensive than their stats suggest because of the bonuses gained by increasing formation size and the possibility of a spare transport space. I'm quite happy with their price.
The FF stat of a MM immolator would certainly be lower than that of the heavy flamer one. Either 4+ and a higher price or 5+ and possibly the same cost.
PostPosted: Thu May 06, 2010 10:45 pm
Then you're talking about two whole datafaxes? Or a split stat?
PostPosted: Thu May 06, 2010 11:34 pm
Could be done either way.
PostPosted: Fri May 07, 2010 3:58 am
Ive seen precedence where a unit is listed in its datafax as getting a different stat depending on which payload you take. I may even try to find it :)
PostPosted: Fri May 07, 2010 7:45 am
Chaos Daemon Princes change their armour rating and speed depending on whether or not they have wings.
PostPosted: Fri May 07, 2010 7:52 am
Aha. It was on The Inquisition's list that I found it! Talk about ironic...
Its the Basilica Imperialis, with a CC 6+(5+) and FF 5+(4+) depending on if you have at least 6 Adeptus Sororitas units on board. Therefore, I think a single datafax with the 2 different stats and notes making it clear would be sufficient.
PostPosted: Fri May 07, 2010 8:20 am
LOL, Ironic Indeed Sir.
I think it would look fine with a split stat razorback.
PostPosted: Fri May 07, 2010 10:58 am
Like I say, it can work either way. I think separate profiles would be cleaner though.
