Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
Adeptus Titanicus Rules?
 Post subject: Adeptus Titanicus Rules?
PostPosted: Tue Oct 21, 2014 8:32 pm
I'm not sure where to post this question, but I'm guessing someone will point me to the correct place if needed.
Does anyone know where I could find a copy of the Adeptus Titanicus rules? I'm looking for the original set. A PDF copy would be great if anyone knows a link.
Thanks!
 Post subject: Re: Adeptus Titanicus Rules?
PostPosted: Tue Oct 21, 2014 10:12 pm
I'd be surprised if it is not on PDF somewhere ... I just put Adeptus Titanicus in my search engine ... found at least 3 links ... give it a try ... ^-^
PostPosted: Wed Oct 22, 2014 1:52 am
If your looking for original 1st edition AT/SM rulebooks and WD articles, PM me.
PostPosted: Thu Oct 23, 2014 8:29 pm
I have found the books I was looking for and then some.
Thanks for the help folks.
PostPosted: Mon Apr 18, 2016 12:53 pm
I too am looking for early rules. I've found the Fanatic issue 85 Rules for AT on the net, but are these just updates to the rules, or the full rules with updates. It states "Updates rules for Titan on Titan action, covering Imperial Titans and Super Heavy Tanks." I'm happy to buy the full rules, I don't want something for nothing, but am a little unclear.
EDIT, I think I've just answered my own question? The Fanatic mag was the amended and updated rules that are AT2?
PostPosted: Tue Apr 19, 2016 7:51 pm
I believe it was for AT2 yes, which originally came out in an issue of the Epic 40,000 magazine before epic armageddon was released.
Sent from my SM-G920F using Tapatalk
PostPosted: Fri Apr 29, 2016 3:00 pm
Thanks for that. I'm reading over old rules systems, and it gets a bit confusing!
PostPosted: Fri Apr 29, 2016 3:24 pm
The AT and Codex Titancus as well as SM1 rules were pretty good. But they were changed to a poorer system with SM2/TL. These systems made a game that "simplified" things, etc., ... And played into GW's concept of making a game where there are so many units on the table it looked Napoleonics or the ACW. Not a modern of even futuristic war game. And in turn GW could sell more models so you could have a game was nothing more than both sides line up and run into the middle and use close combat weapons. :(
PostPosted: Fri Apr 29, 2016 9:40 pm
I LOVE the level of detail and grit in SM1.
If anyone hasn't gone thru that rulebook, I highly recommend checking it out. There was a lot of game in that book. And of course, I love AT and Codex Titanicus too.
PostPosted: Fri Apr 29, 2016 11:11 pm
Many did ! 8)
PostPosted: Sat Apr 30, 2016 2:08 am
I'm in the process of "updating" the SM1/AT rules.
Preserving the feel, while updating the more "sketchy" parts of the ruleset.
For example it was clear from the WD articles that close combat was evolving to what the SM2 rules used, however I will preserve the armor save permitted in CC that SM2 discarded (thus evaluating units like terminators in the process).
I've streamlined and updated the wonderful morale rules (heroic actions!) and introduced flier and psychic rules into the existing turn framework.
The only real "license" I took was to base it on a "2d6" system instead of "1d6" to allow for greater granularity and eliminate the need for fiddly rules to differentiate units because the d6 was too narrow.
I'll be using the SM1 "organizational chart" method for army building, although cleaned up significantly.
The heavy lift of course is to include the wealth and breadth of new units since AT/SM1 publishing.
I already feel it may be the my system of choice. ;)
PostPosted: Sat Apr 30, 2016 2:47 pm
Yep ! We still use the SM1 TO&Es !
!cid_001d01cb7c46$a9a55210$76040A8E@YOURB6C00F138A.jpg [ 112.58 KiB | Viewed 30330 times ]
!cid_015f01cb7c35$2ee93f20$CADADF4B@YOURB6C00F138A.jpg [ 179.67 KiB | Viewed 30330 times ]
!cid_005b01cb7c4a$ac003530$76040A8E@YOURB6C00F138A.jpg [ 138.01 KiB | Viewed 30330 times ]
PostPosted: Sat Apr 30, 2016 2:50 pm
Even did for other Forces that were not around in SM1 ... For example DRM Kray and GW TAU ...
!cid_004601cb7d56$610ecb10$576A7C89@YOURB6C00F138A.jpg [ 124.05 KiB | Viewed 30330 times ]
!cid_00d401cb7c2a$3be67220$CADADF4B@YOURB6C00F138A.jpg [ 93.35 KiB | Viewed 30330 times ]
PostPosted: Sat Apr 30, 2016 2:53 pm
And we did a "Hybrid" version for Traitor SMs & Eldar using SM2 + SM1 ...
!cid_001901cb7d54$83d21820$576A7C89@YOURB6C00F138A.jpg [ 117.13 KiB | Viewed 30329 times ]
!cid_020201cb7c3c$e6c233c0$CADADF4B@YOURB6C00F138A.jpg [ 139.54 KiB | Viewed 30330 times ]
PostPosted: Sat Apr 30, 2016 4:31 pm
Those will be a base, but will be redone to include the updated concepts introduced.
