Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
Old Land Raiders - New Uses
 Post subject: Old Land Raiders - New Uses
PostPosted: Sun Nov 06, 2011 4:42 am
Some old plastic land raiders converted to Spartans from White Dwarf 119.
 Post subject: Re: Old Land Raiders - New Uses
PostPosted: Sun Nov 06, 2011 5:14 am
Ah Yes, the Spartan ... made some a while back , when I saw them in WD 119 ... pretty cool !! Image Image
PostPosted: Sun Nov 06, 2011 5:55 am
Lovely job on those L4. Some old school rules fyi.
PostPosted: Sun Nov 06, 2011 3:43 pm
Thanks ! Yes, yours are very nice too !! ;)
PostPosted: Sun Nov 06, 2011 6:40 pm
Which armies have access to Spartans? IIRC one (or both) of the Squat lists had it.
I have got quite a few of the old Land Raiders and Rhinos kicking around, that I am not likely to use as is (the new models are so much nicer imo) and not likely to sell as I doubt I would get much for them. So the idea of cutting them up and reusing them sounds appealing.
Was nt their 2 different vehicles they featured in WD- the other one used the other bits unused by Spartan. Forgotten the name though.
Thanks
James
PostPosted: Sun Nov 06, 2011 10:19 pm
Just Space Marines use the Spartan ... as a Terminator APC ... The other vehicle conversion that came out at about the same time, was the Sabre, an Assault Gun/Tank Destroyer ... here's my version in Epic scale ... Image
PostPosted: Sun Nov 06, 2011 10:23 pm
Thanks L4- could nt remember Sabre name.
What did you use for innards of Spartan? Is it a plastic rhino flipped over?
James
PostPosted: Sun Nov 06, 2011 10:29 pm
The Spartan I made is just a standard plastic Land Raider model with the metal Mk. 1 Rhino hull inverted, cut and filed to fix. Then the whole model bite'ed out, here and there. I'm sure you could do something similar with a plastic Rhino ...
PostPosted: Sun Nov 06, 2011 11:56 pm
The Spartan terminator transport had an open top and originally used to take squads of terminators through the Ring of Death which forces of Horus had thrown around the captured Adeptus Mechanicus city of Aries Primus. I used the template in WD 119 and then scaled it down to 6mm. All you need is an old plastic land raider and some plastic card.The terminators operating the guns are made from green stuff out of a blue stuff mold.
PostPosted: Mon Nov 07, 2011 12:03 am
The Sabre Tank Hunter ( WD 120) was based on a rhino chasis. Interestingly in the fluff there were tank hunters with missile launchers, lascannon and other heavy weapons but the auto cannon sabre was the most common.
PostPosted: Mon Nov 07, 2011 12:08 am
Old school Sabre Tank Hunter rules.
PostPosted: Mon Nov 07, 2011 12:20 am
3 Penetrator Siege Tanks . See post one above for old school rules.
PostPosted: Mon Nov 07, 2011 11:54 am
Old school rules for the Corona heavy support vehicle. Pictures to follow.
PostPosted: Mon Nov 07, 2011 11:56 am
And the pictures of the Corona.
PostPosted: Mon Nov 07, 2011 4:17 pm
Very nice work !!! Those Sabres look like Russkie SU-85s !!! Image I didn't know about the other two ... certainly looks like a good use for all those extra plastic Raiders & Rhino !! ;) Are those two from NetEpic ?
