Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
The Anphelion Project
 Post subject: The Anphelion Project
PostPosted: Mon Jul 16, 2007 10:25 pm
(Vermis @ Jul. 16 2007,13:41)
However, I could indulge in it (alongside a lot of other fantasy/sci-fantasy concepts)
You didn't read all of it, Orangesm. :;): ?I'm not so bothered by the background, as all the confusion about it.  On this particular subject it seems to me as if every new piece of info contradicts each of all the previous contradictions.  I don't want complete consistency, just a little bit.  Anything.
Jings, I'm being generous to the 40K background here (and I do like most of it, despite appearances/as I said), compared to inhabitants of places like Warseer or Frothersunite.
CS: Because they don't try very hard?
Also, that could be it's name. ?Clive the Malanthrope.
PostPosted: Mon Jul 16, 2007 10:29 pm
My grandad was a Clive... didn't look very Tyranid to me...
Do you think I should sue GW for slurring my families name?
Tom Webb
PostPosted: Mon Jul 16, 2007 11:32 pm
:D
Damn you all. Now I have to name my Epic scale Malanthrope Clive... :p :D
PostPosted: Mon Jul 16, 2007 11:51 pm
It also may be something more like CLI IV so what would that be 151 4 ? First designates Xeno-group or Project and the last digit the species or subject?
Airspace - AeroImp Forum
PostPosted: Wed Jul 25, 2007 6:49 pm
I think that the Lasguns would make a crack when they fire.  When I was in college I went to the office of my physics professor.  Across the hall I heard an intermittent popping sound, which I went to investigate.  In the room was an upperclassman setting up a continuously firing laser for some sort of experiment.  I asked him what the popping sound was and he responded that it was molecules of Oxygen (made up of 2 oxygen atoms) staying in the beam long enough that they were being heated up and forced to disassociate.  Considering the lack of safety protocals being used the laser had to be a rather low-powered one.
If you have a wide enough beam, which it would have to be unless you want to inflict needle-prick wounds in your targets, you are going to catch more diatomic molecules to be split up.  That, and if you actually want to heat/melt/burn your targets enough to actually damage them then you have to have a very powerful beam.  So, if you have a rather wide beam that is very powerful then you are more than likely going to disassociate a lot of diatomic molecules into their component atoms.  What would a lot of "pop" sounds happening at the same time sound like?  Probably a "crack" sound.
PostPosted: Wed Jul 25, 2007 8:23 pm
(Blarg D Impaler @ Jul. 25 2007,19:49)
This is a new one - our beastie boasts 9kW power, and if your hand strays in the lone of fire then THAT would go pop :p . But no molecules ever popped apart, and I storngly doubt the splitting of a molecule would make a sound.
Curious.
Back from oblivion (again)?
PostPosted: Wed Jul 25, 2007 11:47 pm
Now, it's been a very long while since I took quantum mechanics and pchem, but as I recall...
Whether atoms or molecules would dissociate or become superheated would depend on the frequency of the EM wave and various resonating frequencies in the atom or molecule.  If the photon impacts the molecule and either an atomic bond or an electron orbit is in the same frequency, it will impart its energy to the molecule.  The exact effect is going to depend on what lines up with what, but it could be anything from pushing an electron(s) to a higher orbital state (flourescence) to making electrons escape (photovoltaic cells) to increasing physical vibration amplitude (microwave ovens) to causing the electron orbits to completely break down (plasma).
Similarly, it's been a long time since circuits class, but...
Another source of the "crack" similar to the electrical arc theory someone pointed out would be discharge of a set of capacitors.  A set of parallel capacitors could store energy from a relatively low energy power source to allow a brief high energy discharge, which should have obvious applications for a laser weapon.  Depending on the circuit, discharging a capacitor can create an acoustic noise.  A stack of them discharged simultaneously.
PostPosted: Wed Jul 25, 2007 11:56 pm
I think Neal has 5 degrees ranging from Quantum Mechanics to Marketing.
Personally I can tell you a lot about beers and bars and interrogating prisoners but past that...
I think that a laser would make no noise if it was fired in a forest with nobody around... :p
PostPosted: Wed Jul 25, 2007 11:59 pm
Does the Death Star make any noise if the planet is destroyed at the speed of light? :D
PostPosted: Thu Jul 26, 2007 2:12 am
(Moscovian @ Jul. 25 2007,23:56)
Heh. I'm very eclectic.  :D
Of course my wife might phrase that as "attention deficit" or "terminally distracted."
PostPosted: Thu Jul 26, 2007 4:33 am
Wow, sounds like Star Trek Techno-babble, except Neal isn't making it up !  :alien:   :)
PostPosted: Thu Jul 26, 2007 7:00 am
(Moscovian @ Jul. 26 2007,00:56)
Way to go Neal :) :) :)
PostPosted: Fri Jul 27, 2007 1:07 am
So Neal, when you going to write a book and make Millions !?!? (if you have not already !) :;):
PostPosted: Fri Jul 27, 2007 1:13 pm
(Legion 4 @ Jul. 27 2007,01:07)
Heh.  If I had an idea for something I thought was commercially viable, I'd probably take a shot at it.  Right now my book ideas tend to be rather academic -  things like an expansion of speech act theory (J.L. Austin and John Searle) in the direction of Pierre Bourdieu's concept of symbolic violence - sort of use of language as both the means and end of exercising social power.
Of course, I could always write mediocre fantasy novels.  That seems to be a neverending market with rather predictable sales...
PostPosted: Fri Jul 27, 2007 1:33 pm
That actually sounds like something my girlfriend would read.
