Measurements of Baneblade and Shadowswords?
 Post subject: Measurements of Baneblade and Shadowswords?
PostPosted: Sun Sep 11, 2016 2:12 pm
Hi
Can anyone help me with the size of GW Baneblades and Shadowswords? Have never seen them in real life.
 Post subject: Re: Measurements of Baneblade and Shadowswords?
PostPosted: Fri Sep 16, 2016 3:16 pm
You'll probably want to be more specific about which of the GW versions you want. They made 5 different ones IIRC and they've been getting progressively bigger, but more important, the ratio's have changed (from squarish to more rectangular). You're probably most interested in the last versions made I suspect however.
L4, you've got one of everything. Can you bust out a ruler?
PostPosted: Fri Sep 16, 2016 5:27 pm
viewtopic.php?p=594861#p594861
Go clicky the link, it has a few comparisons with at least one dimension measured (and thus the others calculable).
PostPosted: Sun Sep 18, 2016 10:27 am
Thank you very much. Just what i needed.
PostPosted: Mon Sep 19, 2016 12:35 am
The proxy I use for my Plaguereapers are ~5cm and fit well I think
