Frosted ultra detail
 Post subject: Frosted ultra detail
PostPosted: Fri Sep 18, 2015 9:28 pm
Just got an awesome deathbot orb and gateway from shapewayes recently. They look fantastic! However I've heard that frosted ultra detail needs to be treated appropriately in order to keep the greasy film that appears to develop on the surface. I think it was jimmy who recommended sealing it but I don't fully recall. So any recommendations from you guys would be most appreciated! ;D
 Post subject: Re: Frosted ultra detail
PostPosted: Sat Sep 19, 2015 1:07 am
See comments at bottom of this post:
http://hordesofthings.blogspot.co.nz/20 ... icles.html
PostPosted: Sat Sep 19, 2015 1:33 am
Thanks a lot mark. So I guess a simple wash should do then. I assume then there shouldn't be any residual after full cleaned and painted? I'm sure it's fine like you said I just can't shake the memory of someone complaining about the residual even after painting the models. I could be completely off however as I enter my old age. :) thanks again.
PostPosted: Sat Sep 19, 2015 2:43 am
yeah simple wash will do.
The sealing it helps with painting as the material is porous and eats paint like you won't believe.
PostPosted: Sat Sep 19, 2015 3:44 pm
Definitely good to know. Thanks guys.
PostPosted: Sat Sep 19, 2015 6:38 pm
How would you go about sealing it? Spray varnish do the trick? How about brush varnish? I have practically no idea what sealing means, embarrassingly enough.
PostPosted: Sat Sep 19, 2015 8:44 pm
Yeah hit it with same varnish. You don't have to drown it,mind you
PostPosted: Sun Sep 20, 2015 1:11 pm
More help on that: http://www.dakkadakka.com/dakkaforum/po ... ge#8090116
PostPosted: Sun Sep 20, 2015 11:26 pm
I always soak mine in Simple Green for a couple days and then give them a light scrub-down with some warm soapy water. For sealing, a clear primer or "adhesion promoter" seems to work okay.
Set phasers to "fun"!
Visit the
National Cheese Emporium!
PostPosted: Mon Sep 21, 2015 4:27 am
All great advice. Will have to put into practice once school gets off my back! :) In either case thanks for building those awesome deathbots Nolo!
PostPosted: Mon Sep 21, 2015 1:19 pm
The other thing I've found is that dust and lint really sticks to them. Normally if I've left models out on the shelf and they've got a bit dusty, just blowing hard on them and possibly giving them a bit of a wipe with a brush clears the dust away just fine. But with FUD, you really have to make sure you've cleaned all the lint away before priming.
- George Borrow
