Construction Tools for Large Mecha
 Post subject: Construction Tools for Large Mecha
PostPosted: Wed May 13, 2015 8:15 pm
So, I am about to venture into a bit of CADing to achieve a few conversion and modelling goals I cannot achieve via Plastic and GS.
I am decently familiar with both SketchUp and Blender as I use them to create/maintain a scale model of my Church's main venue and a 3d light plot.
So... what is a good scale to start out with in SketchUp? It really seems to fall on its face when doing super detailed small work. I was considering going to meters=mm (1000:1) and then just setting Blender to the proper scale down when exporting the STL files.
anyone see any speed bumps doing things this way?
MadMagician
Epic Tyranids
 Post subject: Re: Couple of CAD questions
PostPosted: Thu May 14, 2015 12:43 am
I thought you only needed blender to do something like this. I had been doing a bit of practice for some basic stuff in blender to export later. Do you need another program to export properly?
PostPosted: Thu May 14, 2015 1:42 am
I think you can do this solo with blender start to finish, I am just faster on Geometric shapes in SketchUp.
MadMagician
Epic Tyranids
PostPosted: Thu May 14, 2015 1:43 am
So our theme is Power Tools for large Mecha...... Our First Entry is a Worm-Drive Circular Saw.
Early cut, needs more detail and a mount. I am trying to work out a universal Reaver/Warlord Mount, but looks liek I will need two to overcome the Beetleback's Angled mounts.
MadMagician
Epic Tyranids
PostPosted: Thu May 14, 2015 3:08 pm
a Little Bit more work this morning. Now Detail and mountings still in the works, Early work on a Reaver Mount as well.
MadMagician
Epic Tyranids
 Post subject: Re: Construction Tools for Large Mecha
PostPosted: Thu May 14, 2015 8:29 pm
I am pretty happy with this! I need to find a better way to do armored conduits, but overall I like it! Next up, a Demolition claw, I think.
<Edit> This is a Reaver sized mount.
MadMagician
Epic Tyranids
PostPosted: Fri May 15, 2015 12:34 am
so, Everything went well till I tried to add Rivets. First some of the rivets (around .2mmx.2mm worked then it got hairy. so any tips from the pro guys out there?
MadMagician
Epic Tyranids
PostPosted: Sat May 16, 2015 11:06 pm
Anyone have some advice on Rivets?
In the meantime, a bit of work on the Concrete Pulverizer.
MadMagician
Epic Tyranids
PostPosted: Sun May 17, 2015 10:06 pm
What you having issues with? (Although I am far from a pro)
PostPosted: Sun May 17, 2015 11:24 pm
NCO, so long story short, I am working in SketchUp. I had added Rivets and hex bolts (about .3 x .3 mm) and they are disappearing in the upload process to shapeways. I have tried meshlab to see if it is a geometry problem and things get funky when I try some of the recommended filters. Also trying to import into blender seems to have issues with parts of the geometry completely missing.
I am not sure if it is an issue with the .dae export or what.
MadMagician
Epic Tyranids
PostPosted: Tue May 19, 2015 4:37 am
Stl export is buggy as hell. Try fixing the file with netfabb Basic or their online service (both are free). Works for me very well. Could also be, that the nuts n bolts must be a bit longer to reach the inside of the case.
