beveling plasticard?
 Post subject: beveling plasticard?
PostPosted: Fri Jan 02, 2015 10:27 pm
Anyone have any tips/tricks with regards to this? I've got two sheets I want to join at a right angle and don't want to show the sheets' edges.
PostPosted: Fri Jan 02, 2015 11:19 pm
Draw a line in from the edge equal to the thickness of the plasticard a pray to the knife handling gods? Or file it?
 Post subject: Re: beveling plasticard?
PostPosted: Fri Jan 02, 2015 11:21 pm
Get a 45deg photo mount board cutter (and pray to the knife gods.)
PostPosted: Fri Jan 02, 2015 11:42 pm
There you go - get a tool - and practice (and pray)
PostPosted: Sat Jan 03, 2015 12:04 am
Perhaps you could bevel two pieces of hardwood, sandwich the plasticard between them and then plane, file and sand the item to shape?
PostPosted: Sat Jan 03, 2015 2:27 am
I like the wooden jig idea, with two holes and wingnuts i can make a clamp.
PostPosted: Sat Jan 03, 2015 4:00 am
I probably wouldn't bevel it unless there was no other option. Instead, make two or three 45/45/90 triangles to hold the pieces and file down any overlap. if you do it right the seam should be invisible.
-Vaaish
