Frustrating as it is, I need to make 2 copies of a small part:
I have some of these parts still on sprue too.
I have tried making a mould in milliput but it just broke apart on demould and stuck to the part even after leaving it for a day (requiring tedious cleaning afterwards). Then I tried making a mould in Polymorph, which I think worked fine but the milliput I used for the actual part also stuck to the mould. I am fairly sure I've had some success with this polymorph+milliput combination in the past (not the best detail but it worked at least), but now I have doubts milliput will ever work with the very thin barrel on these parts.
Is my milliput just gone bad? It seems to stay slightly flexible even after 24 hours, and goes a bit flaky which means it sticks to other surfaces and pulls apart easily. I threw out some air-drying clay (DAS) that had clearly gone bad, is the same true of the milliput? The one I have is the grey & green sticks, it has been kept airtight but the green stick has gone brown on the surface.
Is green stuff any better? Would liquid green stuff work? Any other alternative materials & methods anyone would suggest? So far I am hoping to avoid cracking out the silicone and resin as it's really messy, needs gloves etc and is generally not nice with kids around - especially resin. Presumably resin also has a shelf life too.
