Forgetting Orbital Strikes getting you down? XP Try new BFG!
 Post subject: Forgetting Orbital Strikes getting you down? XP Try new BFG!
PostPosted: Sat Feb 01, 2014 8:03 am
Easiest conversion Idea I ever had, super simple.
all you need is a clear rod about 3mm thick . what ever length you would like, the higher the better it looks.
a BFG ship from your army type .
and a hex from the Expansion: Planetary Empires ,there's a 2 pack expansion of a hive city. its the cheapest one.
and bam! you will never forget to do a orbital bombardment again with this bad boy on your table edge. XD
sorry its not painted I have a lot of terrain projects this year so painting is on the way side. :) enjoy!
File comment: BFG Death from EXTREMELY above!!!
"In the desert, the line between life and death is sharp and quick." Zensunni fire poetry from Arrakis
my gaming blog https://vongutenboom.wordpress.com/
vongutenboomgames instagram
 Post subject: Re: Forgetting Orbital Strikes getting you down? XP Try new
PostPosted: Sat Feb 01, 2014 8:09 am
Nice! :)
PostPosted: Sat Feb 01, 2014 8:33 am
So it's like having a BFG ship on a normal base, except it costs more and you can't use it for BFG anymore?
I mean, thats pretty cool looking, but I'm not sure it's a particularly useful idea. I'm pretty sure the standard proceedure is to use a BFG ship already...
I am considering doing this for use in an actual Planetary Empires map though
PostPosted: Sat Feb 01, 2014 10:07 am
I'm glad you brought that up! it was semi serious post with a bit of a jest sorry I should have used more winky faces ;) but I was just putting the idea out there.
I made it so it comes off the stand for duel purposes it can go back on the BFG stand if I wish. :)
File comment: note the notch I filed in to the rod so it would fit nicely in to stand slot.
File comment: It can still be a BFG ship and an Epic prop at the same time. ;)
PostPosted: Sat Feb 01, 2014 10:41 am
I started magnetizing my BFG fleets. Ships of cruiser size and larger really need it for transportation/storage anyway or they break off their bases. In that context, as long as your polarities are consistent, a bombardment base for Epic is just one more base. :)
