Gothic Buildings for 3D Printers
 Post subject: Gothic Buildings for 3D Printers
PostPosted: Thu Jan 02, 2014 10:19 pm
Hey all,
I've published my gothic buildings on Thingiverse here:
Small Building - http://www.thingiverse.com/thing:217828
Large Building - http://www.thingiverse.com/thing:217827
If you have access to a 3D printer, you can download and give them a shot. They print very well even at low resolution, and you can reduce the infill to 5% to save filament.
I'll be adding photos to the Thingiverse pages as soon as I can get a couple nice shots.
 Post subject: Re: Gothic Buildings for 3D Printers
PostPosted: Fri Jan 03, 2014 8:47 am
Thanks for sharing. Shame that I dont own a 3 D printer
PostPosted: Fri Jan 03, 2014 1:02 pm
nice work. the name might bring the lawyers down on you though :)
My shifting projects
PostPosted: Fri Jan 03, 2014 1:10 pm
Why is that? Honestly, the recent legal experience points somewhere else entirely. I would be flabbergasted if this attracted any kind of IP-troll attention.
PostPosted: Fri Jan 03, 2014 5:00 pm
Very nice. But I'd prefer separate walls instead of full buildings.
As for the IP thing, the Epic40K phrase is being used, that might cause a problem. Gothic as a descriptor should be fine.
PostPosted: Fri Jan 03, 2014 5:54 pm
Ah. That is true. A change to "for use with" or compatible with would clear all doubt. Nice work too. I wonder what it would cost to print?
PostPosted: Fri Jan 03, 2014 7:23 pm
Is it hollow or solid?
PostPosted: Fri Jan 03, 2014 8:18 pm
With MakerBot-style 3D printers, you can specify the amount of infill you'd like. For these, I used as little as 5% without any issues.
So short answer is that it's designed as a solid, but the software will recognize that it doesn't need to be fully filled and can be adjusted to make it nearly hollow.
PostPosted: Fri Jan 03, 2014 9:21 pm
Hmm, what's the quality of the MakerBot printers?
PostPosted: Fri Jan 03, 2014 10:01 pm
I think they're fine for these larger items, but there's no way you'll get a good quality miniature out of them.
