Blast from the past - Malika's old ships
 Post subject: Blast from the past - Malika's old ships
PostPosted: Thu Oct 03, 2013 3:42 pm
So I found my really old photobucket account with all sorts of ships I designed in the past. I might look into them again, tweak them a bit and put them up on Shapeways. Let me know waht you think! :)
Imperial Warpike:
Dagger Class Corvette:
Harbinger battleship:
Broadside Carrier:
 Post subject: Re: Blast from the past - Malika's old ships
PostPosted: Thu Oct 03, 2013 3:45 pm
Very nice! Considering your recent work, I'm positive it won't take you long to tweak them a bit and make them truly awesome! :)
My shapeways shop!
PostPosted: Thu Oct 03, 2013 4:32 pm
The Warpike will be altered a bit to have larger weapon batteries instead of all those small broadside turrets. I'll probably shrink the ship somewhat so it can stand in as a Dauntless Light Cruiser.
The dagger will need some heavy modification, but then it will become a destroyer, or maybe even something smaller.
The Harbinger will have more details added, maybe a few turrets on top, making it a larger transport ship.
The Broadside Carrier will need to be widened up, and then shrunk, to make it a nice alternative for the Defiant Light Cruiser.
PostPosted: Thu Oct 03, 2013 5:02 pm
I really can see the Harbringer as a large transport!
I think the dagger could become a nice fast cutter, or a system ship, depending on the size!
My shapeways shop!
PostPosted: Fri Oct 04, 2013 7:33 am
I was imagining the Dagger as something rather small yeah.
Only one major problem now. Last night I tried to find the original Sketchup files for these models. However, the hard drive they were on died, meaning I can't access the models anymore.
A shame really, but luckily enough I can easily recreate these very quickly. I can also modify them better to fit my own tastes. Which means that the eagle head might be making a comeback. Was thinking of designating these ships as 'Aquila Pattern' or something...
PostPosted: Fri Oct 04, 2013 8:58 am
Aquila pattern! Great minds think alike! :D
I've actually modeled and Aquila frigate, and an Aquila cruiser prow that I haven't printed yet.... If you want I'll post some renders on my plog!
My shapeways shop!
PostPosted: Fri Oct 04, 2013 4:47 pm
Please do! The more the merrier!
PostPosted: Fri Oct 04, 2013 10:24 pm
By the way, here the front part of the new 'Aquila Pattern' Light Carrier. Still needs the whole engine block, bridge, etc.
PostPosted: Sat Oct 05, 2013 2:25 pm
Simply awesome!
My shapeways shop!
PostPosted: Sat Oct 05, 2013 7:12 pm
Thanks dude! I hope the printing will be able to handle the details. That's why some of them seem slightly bigger (like those studs).
In the meantime I've updated the design slight to match the Imperial Warpike. Also to move it slightly away from being too clearly GW.
PostPosted: Sun Oct 06, 2013 12:16 pm
Little teaser...
PostPosted: Sun Oct 06, 2013 1:03 pm
Sweet! How long is it going to be?
My shapeways shop!
PostPosted: Sun Oct 06, 2013 1:37 pm
Plan is for this one to be around 75mm long. Need to see if that will work with all the details, otherwise it might become a little bit bigger (around 80mm at most).
PostPosted: Mon Oct 07, 2013 6:38 pm
Almost done...
PostPosted: Tue Oct 08, 2013 10:12 am
Finished!
