Looking for a 3d designer
 Post subject: Looking for a 3d designer
PostPosted: Fri Jun 28, 2013 2:34 am
Hi,
I've been working on my 2nd ed Epic armies and found that the bikes and cavalry are pain in the the butt on the normal bases with 5 holes. Could someone who is really clever with 3d software maybe create me a 3d template to print on my Brother 3d printer. I'm looking for a standard square epic base with one bike shaped hole in the middle for landspeeders ect and one standard base template with two bike shaped bases for bike and cavalry stands. I suspect it would only take someone who could understand the software a few minutes to do and would save me alot of messing about filling each hole in square base with green stuff so I don't get silly holes in my flock :(
Dean
 Post subject: Re: Looking for a 3d designer
PostPosted: Sat Jun 29, 2013 12:45 pm
No one can help me out? :nooo
PostPosted: Sat Jun 29, 2013 2:05 pm
I just mount things like that on small 20mm square bases ... Image Or 25mm round bases ... Image
PostPosted: Sat Jun 29, 2013 3:49 pm
Or just get some plasticard and cut it into squares?
Let there be code.
PostPosted: Sat Jun 29, 2013 6:24 pm
I can do the model for you, but need VERY accurate dimensions for it - 0.5mm is the difference between too loose and too tight.
My shifting projects
PostPosted: Sun Jun 30, 2013 3:24 am
I'll get those measurements I'd like to try I've thought of sticking to other bases ect but I'd really like to make something for the job and then once its printed I can cast them with my left over resin when I'm casting. :D
PostPosted: Sun Jun 30, 2013 10:10 am
actually - you could just make the master in milliput.
make square, dust with talc, squish bike into it. after it's hard sand the edges to get a nice crisp finish.
PostPosted: Sun Jun 30, 2013 3:12 pm
I tried the green stuff approach it just squashes the base out of shape. sadly :( I'm not very arty I can paint to passing standard but thats about the limit my artistic talent.
PostPosted: Sun Aug 03, 2014 9:03 am
If you can get a bit of thick plasticard, or some magnetic sheet you can cut it to the shape of the base, then cut a shape around the bike stand within that piece of card. If you only have to do it once, and then can cast it it should be a very little bit of work.
PostPosted: Sun Aug 03, 2014 9:29 pm
can help too, if you send all details. Or you can try Tinkercad. Simple tool for a simple job like that.
PostPosted: Thu Aug 07, 2014 12:12 pm
Or SketchUp.
PostPosted: Thu Aug 07, 2014 1:26 pm
At a year's wait, he might have grown the bases in wood :)
PostPosted: Sat Aug 16, 2014 8:09 pm
With my old epic IG bikes I just cut their bases off, filled the 5 holes in the old square bases with green stuff, and super glued them on.
PostPosted: Mon Sep 15, 2014 1:51 am
I made some for the OP last year; I hope they turned out okay. Here is a pic:
Set phasers to "fun"!
Visit the
National Cheese Emporium!
PostPosted: Mon Sep 15, 2014 1:02 pm
Very very sorry, I misread the date, and thought it was June 2014.
Those bases look good though.
Users browsing this forum: No registered users and 77 guests
