Post new topic Reply to topic  [ 143 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
Check this Great CAD Work !!!
 Post subject: Re: Check this Great CAD Work !!!
PostPosted: Fri Feb 14, 2014 1:27 am
No worries - I can do a pack of each -- 2, 4, and 5. Just buying two might not be too competitive, though, since there is a flat "handling fee" with each product ordered. Kind of your classical slope-intercept formula.
Set phasers to "fun"!
Visit the
National Cheese Emporium!
PostPosted: Fri Feb 14, 2014 3:33 pm
Oh, if 5 is an option I'll be buying them in lots of 5. 2 was just there as a compromise option seeing others asked for 4 ;D
PostPosted: Fri Feb 14, 2014 5:50 pm
That's the beauty of 3D printing -- no having to retool molds or anything. All I have to do is update the digital design file and the printer takes care of the rest!
Visit the
PostPosted: Sat Feb 15, 2014 2:29 pm
You have great models! Really looking forward to see the Storm Chicken on shapeways :D
My shapeways shop!
PostPosted: Sat Feb 15, 2014 5:13 pm
Even better if a larger cousin showed up, say a storm turkey :)
PostPosted: Sat Feb 15, 2014 7:54 pm
That would be Christmas!!
My Epic trades list
PostPosted: Wed Feb 19, 2014 7:44 pm
Well, if/when that day comes, I'll be sure to keep you informed!
On the 6mm trucks, I've made packs of 3 and 4 of each variant and will have those up on Shapeways sometime this week.
Visit the
PostPosted: Fri Feb 21, 2014 1:54 am
I have never bought anything from shapewayes before but I am strongly considering atm. Could anyone let me know just how significant a change in detail there exists between frosted detail and FUD?
Also, how hard are the plastics? Are they hard enough where they won't break easily? It's not that I am going to go around hitting them with a hammer or anything, it's just that some of the plastics are described as rubbery and I was curious how hardy the final products are. Thanks.
PostPosted: Fri Feb 21, 2014 3:00 am
Don't know, I just ordered a bunch of the FD rather than FUD ones, on the basis that I've heard there's not a heck of a lot of difference for many purposes.
PostPosted: Fri Feb 21, 2014 3:48 am
Keep me posted Mark! :)
PostPosted: Fri Feb 21, 2014 5:24 am
The differences between FD and FUD probably only matter in the case of the finest details. Otherwise, either should be fine for these.
None of the plastics are rubbery, per se. WSF just has more flex to it than the others. FUD tends to be the most brittle, and small protrusions may break in transit. I tend to find that FD works well enough for most my needs.
Visit the
PostPosted: Mon Feb 24, 2014 10:50 pm
I've found FUD to be somewhere between resin and plastic in its durability/detail. But it's also very much its own unique material. Obviously you don't get print lines in resin (they're very slight in FUD) but FUD doesn't warp or have flash or mold lines.
FUD breaks off the sprue by hand and leaves pretty much no discernible mark. Plastic requires a little more loving.
Resin has a mold release compound that must be washed off, and FUD has that waxy stuff that's similar.
You can get geometries with FUD that simply aren't possible in plastic or resin. But those shapes tend to be the ones with the pointy bits that break off in transit. I suspect that plastic subject to the same constraints would also break. I've had stuff break in transit or even in production, but once it's in my hands I find my plastics breaking more often. My experience is that overall durability is similar to plastic.
Resin and plastic are much, much cheaper.
I have a lot of Einar Gosric's 1/270 space fighters (link). Several have moving and/or interchangeable parts. The parts fit perfectly without filing and there's no rattle. You simply never see that even in plastic. Even with precision models you need some loving to get stuff to fit perfectly. OTOH, some sharp surface details can be slightly fuzzy depending on the printer orientation (designers have been lobbying shapeways to be able to determine print orientation themselves).
Bottom line is that FUD is ideal for most gaming applications, EXCEPT for the price. To me, it's what you use for very special purpose minis that aren't going to be made in bulk. Without shapeways, these either wouldn't have been made, or would have been produced at a loss.
PostPosted: Tue Feb 25, 2014 12:36 am
Also note that it is a good idea to get primer down on FUD pretty quickly. Some older stuff I had printed in FUD and left in storage unpainted is starting to breakdown. It starts secreting an oily substance and the surface becomes sticky. Washing in anything up to and including isopropyl alcohol doesn't improve things any.
PostPosted: Tue Feb 25, 2014 3:35 am
Whoa! I hadn't heard this before. Has anyone else experienced this?
How long was it in storage before the process started?
PostPosted: Tue Feb 25, 2014 3:46 am
Yes I haven't heard anything like that either? Did heat have something to do with it perhaps? I've heard horror stories before of Aussie plastic and resin armies being tragically destroyed by heat.
