Post new topic Reply to topic  [ 570 posts ]  Go to page Previous  1 ... 34, 35, 36, 37, 38  Next
Modeling bits for 3d printing
 Post subject: Re: Modeling bits for 3d printing
PostPosted: Wed Nov 22, 2023 10:42 am
So I've decided to join in the Black Friday madness for all Bits Blitz Designs items on my Cults3d store.
Use the promo code BLITZDISCOUNT to get 50% off all items.
(promo code valid until the 30th of November 2023!)
https://cults3d.com/en/users/BitsBlitzDesigns/3d-models
PostPosted: Mon Nov 27, 2023 2:02 pm
Don't forget to use the promo code BLITZDISCOUNT until November 30th when checking out my Cults3d shop!
PostPosted: Mon Dec 04, 2023 11:51 am
Two new items...
40mm round bases, perfect for your Questoris Knights!
https://cults3d.com/en/3d-model/game/40 ... ty-texture
Gatling Cannons designed to be mounted on the Cerastus Knight arms:
https://cults3d.com/en/3d-model/game/ga ... tus-knight
PostPosted: Wed Feb 28, 2024 12:46 pm
Finally got my 32mm bases ready!
STL's here: https://cults3d.com/en/3d-model/game/32 ... ty-texture
Designed for various scifi 6mm / 8mm scaled tabletop wargames, these bases are perfect for mounting cavalry, light vehicles, or objectives.
Not counting the many details, these bases are about 2.25mm thick.
This kit contains the following parts:
- 10x 32mm diameter round bases
- 10x 32mm diameter round bases with 4x holes of 6.10mm
- 40x 5.80mm diameter inserts for holes in the bases (texture matching the base)
- 40x 5.80mm diameter inserts for holes in the bases (matching texture + additional details bits on top)
Please do not share or sell these files (including prints and remixes) without my written permission.
Note that the final picture with the Squid Drones and Warbikes on top only shows what can be done with these bases. Squid Drones and Warbikes are not included in this kit!
PostPosted: Mon Mar 04, 2024 12:52 pm
Released some smallscale Heavy Warbikes the other day:
STL's here: https://cults3d.com/en/3d-model/game/sm ... y-warbikes
NEWSFLASH!
For those without a 3d printer, I've started a new collaboration with Metal Oak Casting Studios. They've added a bunch of my designs to their shop, the rest will follow eventually!
Go here: https://metaloakcastingstudios.com/coll ... tz-designs
PostPosted: Fri Mar 22, 2024 6:29 pm
Just released these...
Close Combat Brutes
https://cults3d.com/en/3d-model/game/sm ... bat-brutes
Designed for 6mm/8mm gaming in mind. Compatible with games such as Adeptus Titanicus or Battletech.
This kit contains the following miniatures:
- 10 Close Combat Brutes (with 6mm inserts)
- 10 Close Combat Brutes (without 6mm inserts)
*NOTE: 25mm round bases on picture not included in this set, they are available separately though! *
Please do no share or sell these files (including prints and remixes) without my written permission.
PostPosted: Tue Apr 09, 2024 5:15 pm
After several requests I've decided to also do a modular version of my previously released Beta Hab Blocks.
The Beta Hab Blocks are designed for 6mm / 8mm gaming, think of games such as Battletech, Adeptus Titanicus, or Epic.
This kit is basically a modular version of the previous Beta Hab Blocks I've released. It consists of the following parts:
- 4 entrance components
- 7 level components
- 7 roof components
Note that the final picture with the infantry on the roofs only shows how 25mm round bases can fit on the roofs. Infantry and bases not included in this kit.
STL's available here: https://cults3d.com/en/3d-model/game/be ... odular-kit
PostPosted: Sat Apr 13, 2024 9:37 am
Another day, another release! Flamethrowers! :)
https://cults3d.com/en/3d-model/game/sm ... e-troopers
- 10 Flame Troopers (with 6mm inserts)
- 10 Flame Troopers (without 6mm inserts)
PostPosted: Sun Apr 14, 2024 2:09 pm
So I started doodling a bit, and ended up doing a set of eight 50mm round bases!
https://cults3d.com/en/3d-model/game/50 ... ty-texture
Designed for various scifi 6mm / 8mm scaled tabletop wargames, these bases are perfect for mounting vehicles or small mechs.
- 8x 50mm diameter round bases
- 10x little detail bits to add on your bases
PostPosted: Sun Apr 21, 2024 8:13 pm
Alpha Hab Block One:
https://cults3d.com/en/3d-model/game/al ... -block-one
The Alpha Hab Block One is designed for 6mm/8mm gaming, but it could probably be upscaled for 10mm and 15mm scaled gaming as well. This makes the Alpha Hab Tower suitable for games such as Adeptus Titanicus, Dropzone Commander, or Battletech.
The kit contains both single piece as two piece (separate roof) versions of the building.
- 4 single piece Alpha Hab Block One (which each of the 4 roof types)
- 4 separate roofs
- walls put together as a single piece
The dimensions of the buildings are 62.4mm deep and 66.8mm wide. The heights vary (depending on the roof type), but the "walkable" part of the roof is 67.6mm tall.
Note that the final picture with the infantry base only shows how 25mm round based infantry look on and next to the building. Infantry and bases are not included in this kit.
PostPosted: Wed Apr 24, 2024 1:41 pm
Another Alpha Hab Block building? That's right!
ALPHA HAB BLOCK TWO!
https://cults3d.com/en/3d-model/game/al ... -block-two
The Alpha Hab Block Two is designed for 6mm/8mm gaming, but it could probably be upscaled for 10mm and 15mm scaled gaming as well. This makes the Alpha Hab Block suitable for games such as Adeptus Titanicus, Dropzone Commander, or Battletech.
- 3 single piece Alpha Hab Block Two (which each of the 3 roof types)
- 3 separate roofs
The dimensions of the buildings are 77.64mm deep and 65.67mm wide. The heights vary (depending on the roof type), but the "walkable" part of the roof is 83.12mm tall.
PostPosted: Thu May 02, 2024 1:06 pm
Another day, and some new (modular) buildings are out! You can basically stack them up as short or tall as you want, depending on how many level components you wanna print out and cram in there. :)
Alpha Hab Block Three:
https://cults3d.com/en/3d-model/game/al ... ee-modular
The Alpha Hab Blocks are designed for 6mm / 8mm gaming, think of games such as Battletech, Adeptus Titanicus, or Epic.
- 1 entrance component
- 1 level component
- 3 roof components
Delta Hab Block One:
https://cults3d.com/en/3d-model/game/de ... ne-modular
The Delta Hab Blocks are designed for 6mm / 8mm gaming, think of games such as Battletech, Adeptus Titanicus, or Epic.
- 1 level component
- 1 roof component
Delta Hab Block Two:
https://cults3d.com/en/3d-model/game/de ... wo-modular
- 1 level component
- 1 roof component
Beta Hab Tower:
https://cults3d.com/en/3d-model/game/be ... er-modular
The Beta Hab Tower is designed for 6mm / 8mm gaming, think of games such as Battletech, Adeptus Titanicus, or Epic.
- 1 level (single) component
- 1 level (triple) component
- 1 roof component
PostPosted: Fri May 24, 2024 11:22 am
Started working on the 'interior' of the main ship, still needs quite some work. But you're getting the idea. Also added some extra details on the main ship's super structure. Don't wanna put too much detailing on there since I want folks to be able to add all sorts of funky markings on it. And, the landing pod has gotten some additional side thrusters. The crudely kitbashed 54mm tall Drifters are just added for scaling purposes. I'm already pondering a bit about landing gears for the pod.
PostPosted: Tue May 28, 2024 11:43 pm
Finally finished this one, and just had to release it!
The 804-R class tracked transport, also known as the 'Boar', can now be downloaded from my Cults3d.
STL's here: https://cults3d.com/en/3d-model/game/bo ... -transport
PostPosted: Tue Jun 04, 2024 8:59 pm
I know I should spend more time on my own Void Barons setting, or my The Fringe inspired stuff, yet here I am getting distracted doing Adeptus Titanicus compatible parts. This time it's a Cerastus Knight compatible Gravity Gun.
https://cults3d.com/en/3d-model/game/gr ... tus-knight
