Post new topic Reply to topic  [ 259 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 18  Next
Charybdis ordinatus
 Post subject: Re: Charybdis ordinatus
PostPosted: Mon Aug 23, 2010 10:40 pm
Commentary found on DeviantArt by the artist
"A massive energy weapon for use against orbiting targets. Not really designed to travel cross country due to ground pressure, but able to shift position to avoid counter battery fire. Coupled with an orbiting network of DEW stations called Scylla for fire control."
PostPosted: Fri Aug 27, 2010 2:14 pm
Progress.
PostPosted: Fri Aug 27, 2010 2:19 pm
Dwarf Supreme wrote:
Are you going to make it so that it can be either limbered or unlimbered?
Sorry, it took me some time to realize that you meant if the gun could be positioned in a non-firing (i.e. travelling) position.
It is a consideration, but the difficulty is somewhat daunting. Time will tell, I guess.
I also need to figure out some way of making the weaponry modular so that we can cram other interesting stuff on there for Ordinatus fun. Perhaps an Imperator sized plasma cannon? Or a Warmonger sized vengenace cannon? Well, maybe not the cannon. The design implies non-recoil weaponry. Oooh! A big-ass railgun! It could use all of the juice stored up in the capacitor cars.
PostPosted: Fri Aug 27, 2010 10:32 pm
Oooo, I like the idea of a modular weapon system.
PostPosted: Thu Sep 02, 2010 10:51 pm
Some more work. We're in an awkward stage.
PostPosted: Thu Sep 02, 2010 11:36 pm
Hey Otterman, I was thinking of ways you could add a bit of imperial flair to your model. How hard would it be to modify the structural framing on the platform arm into something similar to the cross bracing on the necromunda bulkheads?
PostPosted: Tue Sep 07, 2010 4:29 pm
I'm trying to stick close to the source art for this particular Ordinatus. When the time comes for a right-and-proper 'Albanian' Ordinatus, those bulkheads will serve well as inspiration.
PostPosted: Tue Sep 07, 2010 4:52 pm
Please continue with your awesomeness.
PostPosted: Mon Nov 08, 2010 3:36 pm
Wakey wakey, Charybdis! Show your progress to the nice people.
I had to choke down the bile while working on the tracks, but found therapy by copying GHQ's M1A1 style.
PostPosted: Mon Nov 08, 2010 4:11 pm
Not bad ... I thought I recognized the M1 influence ... ;)
PostPosted: Tue Nov 09, 2010 3:39 pm
That'll do, pig. That'll do.
PostPosted: Tue Nov 09, 2010 3:51 pm
Nice pully-thingy O-man.
PostPosted: Wed Nov 10, 2010 10:00 pm
Oh command bridge, why can't you be impressive like the Skinners' projects?
PostPosted: Wed Nov 10, 2010 10:53 pm
I like food.
PostPosted: Thu Nov 11, 2010 3:41 pm
Then why don't you make us some metal genetically engineered man scouts?
