Page 1 of 2 |
[ 28 posts ] | Go to page 1, 2 Next |
Venerable Battle Barges |
| rowanalpha |
| Top | |
| Xisor |
| Top | |
| Admiral d'Artagnan |
| Top | |
| rowanalpha |
| Top | |
| Top | |
| rowanalpha |
Here we get into the fuzzier realm of game balance. A standard battlebarge is more heavily armored than a battleship, but mounts less shields and turrets. The reality is that the battlebarge is not any more or less fragile than a battleship, its just that it makes barges better tagets for lances and battleships better targets for weapons batteries. Comparatively, imagine if 40k spacemarines had a 4+ inv save instead of 3+ armor. Heavy weapons would have a harder time cracking them, but massed small arms would become more effective. The same principal of balancing vulnerabilities applies here. Also, I believe your lance conversions are skewed. It should be closer to Str 1,60 cm = Str 1.5,45 cm = Str 2,30 cm. _________________ The Construction Worker Space Marines like to paint Yellow and Black Stripes on Everything. This is for Safety. They also like to Blow Up Stuff. This is for Unsafety. They are very complicated people. This is why they are very (x2) popular. ? Sneak Preview of Construction Worker Space Marines |
| Top | |
| Hellebore |
| Top | |
| Top | |
| rowanalpha |
I apologize, I don't think my metaphor was clear. Consider shields as the "invulnerable save" and armour value as the "armor save". By increasing one and decreasing the other, the ship (or Space marine) does not become that much more or less tough, it(he) just survives some attacks better and some attacks worse than previously. Its a probability adjustment. The reason I say there should be a reduction in shields and turrets when we raise the armour value is that if we did not, the ship would become prohibitively expensive. Remember, the ships armour value directly affects how many shields will be knocked down by weapons batteries and how many bombers will actually hit the ship. For gameplay, you don't WANT to make a ship that is completely invulnerable because that would be no fun to play against. True, it does make logical sense that the imperium would want its shock troops to be as well protected as possible, but the guys who designed the game decided the battlebarges would be too tough for play with 4 shields and turrets. Look at it this way: The standard barge is 425 points with 3 shields and 3 turrets. If it went to 4 and 4, the ship would have to sustain 33% more damage befor taking hull damage, and ordnance would be 33% less affective against it. This means that, to balance, the ships cost would have to increase 100 points, if not more. _________________ The Construction Worker Space Marines like to paint Yellow and Black Stripes on Everything. This is for Safety. They also like to Blow Up Stuff. This is for Unsafety. They are very complicated people. This is why they are very (x2) popular. ? Sneak Preview of Construction Worker Space Marines |
| Top | |
| Hellebore |
| Top | |
| rowanalpha |
Actually, a shield is a form of invulnerable save. A Battlebarge will automatically save the first three wounds it suffers each turn before it is actually damaged. Take this into consideration. If a ship has 5+ armour and 4 shields, it should take (statistically) 12 weapons battery dice to knock down the shields and then the ship will suffer one point of damage for every 3 dice after that. The battle barge, by comparison, with its 6+ armour and 3 shields needs 18 battery dice to knock all of the shields down and 6 more to cause each point of hull damage. Now what if the barge had 4 shields? It would take 30 dice to cause 1 point of damage, where the average battleship would take 6 points of damage from the same 30 dice. Next consider lances, the math here is easier. A 5+ armor, 4 shield battleship suffers 1 point of damage if 10 lances are fired at it, where the barge will suffer 2 from the same attack. But increase the shields to 4, and it takes the same damage. By taking the barge to 4/4, it retains double the standard battleship's resilience to weapons batteries but matches the battleship's capacity for lance damage. The crux of the arguement it this: The SM fleet, as a matter of being different than the Imperial Navy has different strengths and weaknesses. Its strength is that it is less vulnerable to weapons batteries but its weakness is that it is more vulnerable to lances. That's not bad news, and its not good news, its just the news. If you're not willing to play within the contraints for a fleet's design, don't play the fleet. Its the same reason necrons have no ordnance, that eldar ships are made of tissue paper, and that Tyranid ships all move 15 cm. The SM fleet is not defecient, it simply requires more awareness of its facets to play than the Imperial navy. If you look at this as a challenge to be overcome rather than a problem to be fixed, you will be more successful. _________________ The Construction Worker Space Marines like to paint Yellow and Black Stripes on Everything. This is for Safety. They also like to Blow Up Stuff. This is for Unsafety. They are very complicated people. This is why they are very (x2) popular. ? Sneak Preview of Construction Worker Space Marines |
| Top | |
Page 1 of 2 |
Who is online |
Users browsing this forum: No registered users and 35 guests |
