Battlefleet Prometheus
 Post subject: Battlefleet Prometheus
PostPosted: Fri Dec 02, 2005 3:24 pm
Well, it's Battlefleet Prometheus(I know, I know, it's Nocturne that's the Homeworld, but it's Prometheus where this fleet docks, Battlefleet Nocturne is a smaller IN Fleet with Salamanders having their 'hands in the pot'). Basically a 'retry' at the failure that was the Dominion Fleet List.
I also wanted to represent the product of a highly technically proficient Astartes Chapter and what you get when you combine that with the Adeptus Mechanicus. To me, that means 'more BBs', which is what I'm going for with this list.
It's also not long thought out, so...
Battlefleet Prometheus- A Salamanders Fleet List
Fleet Regent (As Master of the Fleet)
Battleships
The Salamanders are known for their ultimate prowess with technology, and maintaining repair standard on far older vessels. In this manner, Salamanders are known to maintain an extraordinary  number of various configuration Barges.
0-3 Battlebarges (Standard) (1/750pts or part thereof)
0-2 Venerable Battle Barges (1/1000pts or part thereof)
0-1 N?bel?s Hammer ???pts
Cruisers 0-10
Whilst most chapters maintain a sizeable force of strike cruisers well in excess of their amount of Battlebarges, the Salamanders curiously maintain an unusually small number of Strike Cruisers compared to other former Legions. It is known that they often employ and serve alongside starships of the Imperial Navy contingent of the system?s battle fleet.
0-6 Strike Cruisers- 145pts
0-4 Nocturnian Reserves- Varies
Nocturnian Reserves:
The Salamanders are known for the power, not the numbers they posses. Their good relations with the Adeptus Mechanicus and the Imperial Navy in the Sector allow them to maintain a standing, if minor, relation with the Naval Ships in the system. It is quite common for a handful of Salamanders Battlebrothers to serve aboard Naval Vessels operating alongside the Promethean fleet, often as advisory roles, alongside the Commissariat and often even paired with the Adeptus Mechanicus Contingents onboard the starships.
A Promethean fleet may contain, to a maximum of four in total:
0-2 Lunar Class Cruisers 200pts
0-2 Tyrant Class Cruisers 205pts
0-1 Dictator Class Cruisers 230pts
These vessels gain the following benefits:
- +1 Ld (from standard leadership table)
- Double ?Repair? Damage Dice in end phase
- Gain a Special Torpedoes roll each battle
Escorts
A Promethean Fleet may contain any number of Gladius, Nova or Hunter class Escorts.
Gladius Class Frigate- 45pts
Nova Class Frigate- 50pts
Hunter Class Destroyer- 40pts
A Promethean Fleet may contain up to two squadrons of Battlefleet Nocturne Escorts plus one extra squadron per Nocturnian Reserve Capital Ship in the fleet.
Falchion Class Frigate- 35pts
Sword Class Frigate- 35pts
Firestorm Class Frigate- 40pts
Type/Hits      | Speed | Turns | Shields | Armour | Turrets
Battleship/12 | 20cm   | 45     | 4         | 6+      | 4
Armament                   |Range/Speed | Firepower/STR      | Fire Arc
Dorsal Weapons Battery | 45cm          | 8                       | FLR
Port Weapons Battery    | 45cm          | 6                       | Left
StBd Weapons Battery   | 45cm          | 6                       | Right
Prow Nova Cannon       | 30-150cm | 1                       | Front
Port Launch Bay       | THawks 20cm | 2                     | -
StBd Launch Bay       | THawks 20cm | 2                     | -
Port Lances                 | 45cm           | 2                      | Left
StBd Lances                | 45cm           | 2                      | Right
So, it's not fully thought out, but I'm a fan of the Salamanders, and I think this is quite a nice list, inventive and something new for the Imperium, hopefully not groundbreaking though. I'm tempted to put the Nocturnian Reserves as 'Grand Cruisers Only', so as to keep up the feel of Marines not having/using Normal Cruisers. What do folks think of that as an alternative?
Xisor
"Number 6 calls to you
The Cylon Detector beckons
Your girlfriend is a toaster"
PostPosted: Fri Dec 02, 2005 5:22 pm
Okay, double posting I know, but it is essentially a 'reply' to my post...
Anyway.
The last points I make about Grand Cruisers, I thought even more about this, I can't help but feel this is a very 'good' way to go with Marine fleets. Gives them a bit of added 'oomf', but in true SM BB-esque styles.
So, 'alternate' Nocturnian Reserves:
Max of 4
0-4 Avenger Class Grand Cruisers- 240pts
0-2 Vengence Class Grand Cruisers- 230pts
0-2 Exorcist Class Grand Cruisers- 240pts
[It's mentioned in fluff that Grand Cruisers form major parts of 'reserve' fleets and fleets for generally safe areas. I quite like the idea that the Nocturnian forces keep using them because they can afford to keep them in good condition for fighting with, and not just 'reserve' duties{remember, these are reserves to the Salamanders, not to the IN}]
'Upgrades'-
+1 Ld
+2 Damage Repair Dice
+1 Modifier in Boarding Actions
Escorts:
Firestorms, Falchions, Swords as normal, but only 2 Squadrons + 2/GC extra.
Otherwise, what I already said applies.
Now, for a bit of my 'fluff' reasoning:
Salamanders operate 'larger' than normal Companies, not by much, but certainly significantly. In this manner, I can see a 'rough' situation of the Battle Companies being on permanent 'embarkment' on one of the various Battle Barges, and where many chapters would deploy a SC, the Salamanders can afford to deploy a BB. It also allows them to play more 'intractably' to the fluff. There's no point hanging about trying to save everyone if your ship will be crippled in 4 hits  :down: ! Well, there is, but I think being 'larger than life' is quite an interesting quirk for a Salamander Fleet, and I can't think of a chapter that are more suited to it.
They do have Strike Cruisers and their escorts however, which IMO would have very 'light' complement on them 'marine-wise', often used for the far more 'noble' duties of convoy protection often 'ignored' by other chapters. Roving patrols, expert/rapid but small scale anti-pirate moves and such too. When Salamanders go 'in force', then I imagine it'd be their BBs they move in, not their SCs...
Of most atypical note of all, it could be noted that since the Salamanders have such a huge 'cargo' capacity for such a small chapter(18 Companies worth of BB, 6 SCs and whatever space they have on the rest of the fleet) that they are not unknown to attempt to ferry thousands of refugees out of the most dangerous and terrible of combat zones in their own ships!
Again, it plays to the fluff IMO.
Then again, with such a preponderance of BBs, it's also likely and nowhere near uncommon, that Salamanders will often be requisitioned to perform Exterminatus more often, they do have more equipment...
Xisor
PostPosted: Fri Dec 02, 2005 5:24 pm
This is a good shot at a variant fleet list, mainly because it doesn't just try to rewrite the army's 40K special rules for BFG.
The repair bonus on the reserve ships captures the Salamander's flavor well, and I think you should add it to the regular SM ships also.
I only have a couple of concerns with this list, mostly the details:
Battleships
A simpler execution of this might simply to say:
Battlebarges
A Salamanders fleet may have 1 battlebarge of every full 500 points the fleet is worth. You may not have more Venerable Battle Barges than standard Battle Barges
0-3 Battlebarge
0-3 Venerable Battle Barge
     (inc N'bel's Hammer)
Nocturnian Reserves
I'd suggest taking the Dictator out in favor of a Gothic.  I say this for two reasons: 1. It gives the SM fleet access to bombers, when the fleet's ordnance should be focused on boarding, and 2. This would be the place to give access to a limited number of lances.  Point two also leads to my final observation
I would recommend dropping the lances (Since SM ships should not have lances), pushing the L&R batteries to 60 cm (to balance the loss of the lances), and replacing the dorsal battery with a bombarment cannon (same strength, 30 cm, to bring in line with normal BBs)
Once again, praise for this being a simple, effective rendition of a specific space marine fleet.
The Construction Worker Space Marines like to paint Yellow and Black Stripes on Everything.  This is for Safety.  They also like to Blow Up Stuff.  This is for Unsafety.  They are very complicated people.  This is why they are very (x2) popular.  ? Sneak Preview of Construction Worker Space Marines
PostPosted: Fri Dec 02, 2005 6:20 pm
Thanks for the praise on that ?:D
I think I'll revise the Damage Repair things to +2/Ship. For SCs this means 8, GCs 12, BBs 14. Only a small addition, but there you go.
The BB Suggestion/simplifcation is a good one, I might as well stick to that too.
The Dictator is only ship, so at most 4 Bombers. Simply that these ships come from the Nocturnian fleet, and aren't 'strictly' TH-Bombers(unlike the bloody anhiallator thunderhawk, ). Anyway, I personally now prefer the GC Suggestion I made, kind of reinforces the 'fleet' feel. I'm particularly fond of the ideas of an almost all Avenger/BB/Gladius force...that strikes me as a very potent 'Firefight' force, just like the Salamanders should be. Again about the GCs, I'd imagine the fact that they're 1) more pricey than normal cruisers and 2) Play differently to normal fleet cruisers(no armoured prow, no forward weapons, more shields/hits) they should complement a Marine Force oriented the way I suggest, but they wouldn't cover it's weaknesses(which is a good thing).
One of the things I find with this approach to the fleet is that the fleet format itself, IMO, plays to the fluff of the Salamanders, not the special rules or tweaks. IMO most variations for Marine fleets should come from orginisational changes: ie what fleets can actually be made of.
In this respect, if need be, I'd be happy to lose the special rules, but feel for now, they're characterful.
EDIT: Regarding the N'Bel's Hammer, I'd say keep the lances, but I understand why they wouldn't be 'liked'. I've had a couple of thoughts about it:
1- It's a pre-heresy era ship, even sufficiently pre-great crusade.
2- There's not many lances, and they're not long ranged, so we've no SO problems.
3- The 'look' I'm thinking of for this ship is Vengence + Battlebarge, a small 'pod' of lances make sense for a pre-heresy flagship that'd look silly if it got caught out by someone.
4- Salamanders have good relations with the Adeptus Mechanicus, and I imagine quite favourable relations with copious circles of the Inquisition. They're not a problematic(ref: Space Wolves, Iron Hands), erratic (ref: Black Templars, Flesh Tearers, Blood Angels[to a degree]) and don't seem to be suspicious (ref: Dark Angels, Relictors), so, like the Ultramarines, I imagine they aren't bothered too much by operating 'slightly above' conventional Space Marine Methods.
That said, I'd be half tempted to put the Lances on top(S2, 60cm), and have the broadsides be BCs, WBs, LBs.
What I'm worried about is the Nova Cannon. I liked it because it's a very cool idea IMO to have something this potent on a VBB, it's one of a kind(like the SO was unfortunately...), and I'd be tempted to plop BCs or Torps on in its place...but then again, I still like the idea.
Xisor
PostPosted: Fri Dec 02, 2005 10:48 pm
Half decent IMO.
First, +2 repair dice for all ships is a lot better than double repair dice for the reserves.
The +20pts for +1Ld, Special Torps, and the better repairing is too cheap, the special torps alone are normally worth +20 points.  Good thing you changed to GCs (which I think fits nicely).
Definately redo the BB restrictions.  As it stands, your fleet could be a couple BBs and the Fleet Regent.  Maybe 1 per full 750 points, and if you have two or more BBs, the VBBs may not outnumber the normal BBs.
Are the Nocturnian Reserves bought by reserves?  I don't think so, so I'd say Nocturnian Reserves may not outnumber the SCs. Otherwise the Salamander fleet could be a couple BBs and four IN cruisers.  I don't know the Salamanders fluff, but IMO that would be an IN fleet not a SM fleet.
For the Nocturnian escorts I'd stick with 2 squadrons plus 1 squadron per GC.  Chances are if anyone takes four squadrons of Nocturnian escorts they won't have any SM escorts unless it's a very large game.  Personally I'd add the restriction that the Nocturnian escort squadrons may not outnumber the SM escort squadrons.
-Archer
PostPosted: Fri Dec 02, 2005 11:17 pm
I'm also proposing(though not betting it all on) the idea that this is a bit of a variant...a bit like the Armageddon fleet list...but different. Essentially a replacement for 'mixed' Dominion Fleets(wheras Ultramar, IMO, would maintain a Space Marine Fleet and a decent sized battlefleet. For 'Battlefleet Nocturne', I'm thinking half a dozen Grand Cruisers and a dollop of escorts. Thus Battlefleet Prometheus, being a BB oriented Marine force[again like the all Explorer Tau force, I don't mind the idea of a 3 BB Fleet, in fact I see it being a particularly Salamandery thing to deploy].
I did have 'another' consideration...that of allowing a 'standing force' of Venerable Strike Vessels, that is Marine Converted Exorcist as a standing part of the fleet:
So, Basic Exorcist +
Marine Rules
Thunderhawks instead of normal AC
Exterminatus Array on the prow/PA Bonus etc etc
I'd say 0-4 as part of the normal 0-10 Complement of Cruisers standing for Battlefleet Prometheus.
Then put the Nocturnian 'Reserves' in as simply 'cannot outnumber SCs or VSVs'. That'd allow the allowance on BBs to return 'slightly'. The problem with a 1/750pts FULL is that you need 1500pts to field 2 BBs, in a normal SM Fleet, that limit is 1001pts+.
On the 'escorts may not outnumber marine escorts' point, I just feel thats a bit arbitrary. As I see it, this is also a bit of a stand in for the Dominion Fleet list, that is a Marine force that has the ability to do 'non marine things', ie last a firefight with a heavy gunship fleet and come-back fighting, so the Marine presence would be the 'over arcing presence', not necesserilly the bulk of the presence.
Then again, that is just an impression of things...it's not as if we have anything concrete to go on...
PostPosted: Fri Dec 02, 2005 11:41 pm
Nice Xisor.
Remarks:
- Battleship selection is no problem IMO.
- Have to agree to drop the Dictator.
- Nova on the N'bell is asking for trouble. People would accept it without sooner.
- Indeed upping battereies on it and dropping lances is better.
Space Marines everywhere (4 WIP). Need to go over to another race... :p
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Fri Dec 02, 2005 11:56 pm
What about the Grand Cruiser suggestions?
Xisor
PostPosted: Sat Dec 03, 2005 7:32 am
I would say instead of making the double repair damage, simply give them an extra dice. It isn't much, but I think that a ship rolling 10+ dice to repair each phase is a bit over powered.
And being so large, I doubt you could repair something that fast.
Apart from that, I like the list- it is what I think of when it comes to variant lists- no uber special rules, just some interesting fleet restrictions.
after the space wolves, the Salamanders are my second favourite chapter- just something about them.
hellebore
Torpedoes a Go-Go Cap'n!
PostPosted: Sat Dec 03, 2005 8:44 pm
Hellebore: I think I've came around on the Repair Dice suggestion, either +1 or +2 Dice should work nicely(maybe +1 for a cruiser, +2 for a BB).
Xisor
PostPosted: Sat Dec 03, 2005 11:42 pm
Maybe you could have Techmarine upgrades similar to Admirals.
Techpriest Artificer - Xpts (gives 1 extra repair dice)
Techpriest Artificer Lord - XXpts (gives 2 extra repair dice)
just allow ships to take it as an upgrade, with maybe a mandatory lord for the lead ship.
hellebore
PostPosted: Sun Dec 04, 2005 5:47 am
I think the flat +2 repair dice bonus across the board is a sound bonus.  Worthwile, but not unbalancing.
Hellebore has the right idea, variants should be slight tweaks, not volumous additions, and this list accomplishes that goal.
I occured to me that you might actually want to put a restriction on the fleet's strike cruisers, maybe one per BB max.  This would make the fleet much more "slow and purposeful" if you will, capturing the Salamander flavor (especailly in 3rd ed when they had -1 initiative).  This would also serve as a balance to the repair bonus (what little balance would be needed).
PostPosted: Sun Dec 04, 2005 6:40 am
I feel uneasy about that imposed limit. They 'do' have access to them, and they would deploy them, it'd just be unusual for them to do so(and I don't really see the need to confine the player when they're likely to be doing so themselves anyway).
I think the limit on SCs as it stands is currently quite a striking thing(pun intended?). Well, I'm tempted to say 0-5 SCs and 0-5 VSVs/Reserves as 'cruisers'. Why? well, SCs are only really useful in decent sized squadrons, and this says to me, that you can only get 1-2 decent sized squadrons out of that.
Perhap, OTOH, you must have 1 BB/VSV/Reserve for every two more than one Strike Cruiser. So:
1-2 SCs = Optional 'Heavies'
3-4 SCs = 1 'Compulsary' Heavy
5 SCs = 2 Compulsary Heavies
Thats off the 0-5 SC limit. Slightly complex, but again it's only a fleet restriction, but doesn't deny the fact that Salamders still often do operate 'typically' as SM forces(so you can still field a roughly 'standard' small Space Marine force of 2 Strike Cruiser + some SM Escorts as normal, but when you try to go above that, they become far more noticably different, which is very much Salamandery IMO).
+2Repair Dice seems the easiest and most obvious way to go, not least because having a 'techmarine lord' is what the Salamanders are all not about. 'Each Marine is capable of maintaining his own armour and weapons', Self Reliance etc etc. Each Marine(and from that, each Promethean Cult memeber aboard the ship) is generally very technically proficient, meaning the techmarines themselves are able to do more interesting things than rush about the ship sealing up detonating conduits...Essentially, it's the Salamanders and Promethean Cult Members themselves that are self reliant and excellent with the maintainance/repair, which is entirely(unless I'm mistaken) unlike other known chapters.
Xisor
PostPosted: Tue Dec 06, 2005 5:31 am
That is true (re self reliance) but the systems on a ship more than 2 km in length I think are past the ability of a tactical marine to repair.
In the 40k universe, NOONE understands technology, so a Salamander battle brother with 1% tech knowledge knows an infinite amount more than an average citizen that knows nothing.
I would liken each marine's expertise to that of the DIY home handyman- he knows the basics of fixing his car, repairing damaged furniture, cleaning the gutters etc, and could even MAKE things like tables and stuff.
THat doesn't mean he knows how to repair a formula 1 car.
Or to put it another way- a trained army engineer may know how to fix an APC's drive shaft, or unblock the breach of vulcan cannon, but asking him how to fix a NAVY destroyer engine, and he will probably give up.
Knowing how to fix ones own armour and weapons does not necessarily equate to being able to fix someone elses 1000 trillion tonne+ starship:D
hellebore
PostPosted: Tue Dec 06, 2005 3:14 pm
Perhaps I am overestimating the strengths of the Promethean Cult, but self reliance, interaction with friendly and reliably useful superhumans who specialise in knowing how to keep in good repair their technology and all the other things the Cult espouses, I don't see why the serfs and crews who are part of the Cult won't just be as good as other serfs, I'd expect them to be amongst the best crews in Galaxy...
Black Templar Crews, just because they're a space-going chapter, doesn't mean they're much better than everyone else. In fact, I'd wager the BT ships are not held in the best standards of everything.
It's not 'just' the Marines, it's the effect the marines have. The Salamanders are known for not being arrogant, jealous and selfish with their assets. With the Nocturnians, the Salamanders interact often and well, they act as leaders and mentors, figureheads, heroes and inspirations. I wouldn't half doubt that the technical colleges on Nocturne aren't filled to the brim with practically minded mechanics and technicians.
Then, figure those who go through the trials to become a Salamander, all those dropouts, joining the serfs of the Salamanders. Put them through the technical training and 'cult' that the Salamanders go through, and you'll have the maintainence of a Salamander in all but sheer strength, toughness and longevity.
And if that's just the basics, imagine what they'd do when overseen with a proper techmarine!
They may not 'understand' the tech, but they certainly know how to keep it going!(As an example, in our Physics Lecture the other week, on doing rotational movement the lecturer pointed out why you need to get your wheels balanced on your cars, and said roughly: "So, your mechanic may know exactly how to fix the damn things, but unlike you lot, he's unlikely to have much knowledge as to why they need fixed in the first place").
Xisor
