Space marine Battle Barge Variants
 Post subject: Space marine Battle Barge Variants
PostPosted: Sat Dec 03, 2005 10:58 pm
Space Marine Capital Ship Variants
Space Marine Assault Barge: 400 points*
Type/Hits: Battleship/12
Speed: 20 cm
Turns: 45
Shields: 4
Armour: 6+
Turrets: 4
Armament | Range/Speed | Firepower/Str | Fire Arc
Port Launch Bays | Thunderhawk: 20cm | 2 squadrons | -
Starboard Launch Bays | Thunderhawk: 20cm | 2 squadrons | -
Prow Launch Bays | Thunderhawk: 20cm | 3 squadrons | -
Prow Bombardment Cannon | 30cm | 3 | Left/Front/Right
Dorsal Bombardment Cannon | 30cm | 8 | Left/Front/Right
Notes: The Assault Barge may replace its Prow Bombardment Cannons for Strength 6 torpedoes at no extra cost. The Assault Barge also earn 3 Assault Points for every turn they spend landing troops or bombarding the planet rather than 2 as is normal for SM.
Space Marine Exterminator Barge: 500 points**
Speed: 20 cm
Turns: 45
Shields: 4
Armour: 6+
Turrets: 4
Port Bombardment Cannon | 30cm | 8 | Left
Starboard Bombardment Cannon | 30cm | 8 | Right
Prow Launch BaysLaunch Bays | Thunderhawk: 20cm | 3 squadrons | -
Notes: The Siege Barge only earns 1 Assault Point for every turn they spend landing troops or bombarding the planet. However, in Exterminatus scenarios, it only needs to roll 2+ to exterminate a planet.
Acknowledgements:
A lot of the base stuff I used is based from Games Workshop. I also acknowledge Xabre who designed the Assault Barge and who did a lot of the work in coming up with points. The Exterminator Barge is my design.
PostPosted: Sat Dec 03, 2005 11:02 pm
Xabre and I figured the SMs shouldn't really have much variants on the Battle Barge's but these should work for the experimental SM fleet list. Standard BB for Dominion, Assault BB for the Planetary Assault, and Exterminator for the Crusade (although one can also use the Standard BB with TH Annihilators).
