Iyanden fleet list
 Post subject: Iyanden fleet list
PostPosted: Thu Dec 08, 2005 7:53 pm
Note about Dragonship & Shadowhunter in Biel-Tan thread.
Fleet Commander
You may choose an Admiral or Fleet Admiral to lead the fleet. Fleets greater than 750 pts must include a Lord to lead it. Fleets of greater than 2000 pts must include a Fleet Admiral.
The Seer Council may only be taken if your fleet includes a Fleet Admiral to lead it.
0-1 Admiral 50 pts
Leadership 9, 1 re-roll
Fleet Admiral 100 pts
Leadership 10, 1 re-roll, +1 boarding
A Fleet Admiral may be upgraded to ?Hero? status for +50 pts.
A Lord can take extra re-rolls at the following cost:
One Extra Fleet Command re-roll 25 pts
Two Extra Fleet Command re-rolls 50 pts
Three Extra Fleet Command re-rolls 100 pts
0-1 Seer Council (comes with one Foresight power) 100 pts
A Seer Council can have extra Farseers at the following cost:
One extra Farseer (+1 Foresight power) 50 pts
Two extra Farseers (+2 Foresight power) 100 pts
A Seer Council starts with one Foresight Power (FSP) and can gain up to 2 more by adding additional Farseers. A Foresight Power allows any one ship to go onto BFI (automatically) after the dice have been rolled to hit, gaining a 4+ retroactive save against each hit scored (re-roll criticals). The use of this power does not have to be declared before rolls to hit and overrides the Eldar Arrogance special rule. Can only be taken if the fleet has a Fleet Admiral to lead it.
Spiritseer - 25 points
You may take one Spiritseer for every 500 points or part thereof.  They must me stationed aboard a Ghostship
Each Spiritseer has one reroll that may only be used by the Ghostship the Spiritseer is aboard and it's squadron.
Also, half of the capital ships (see next point) will be Ghostships so this is a way to provide re-rolls for half of the Iyanden fleet.  Hopefully the 500 point limit keeps Ghostships doing nothing occasionally.
Capital Ships
Flame of Asuryan [I[if fleet led by Hero[/I] 320 pts
+ 20 pts for aspect warriors (note, model has a-boats)
Dragonship 260 pts (1 per 2 Wraithships)
+ 20 pts for aspect warriors, + 10 pts for a-boats, +10 pts for boarding torps.
Wraithship 160 pts
Ghostships free fleet must consist of at least 50% of ghostships
Ghostships   have -1Ld. If one fails a command check it will do nothing in the turn (or following turn in case of BFI) but you may still attempt further command checks for ?living? ships, though not for other Ghostships. Further, Ghostships cannot benefit from command re-rolls, though they can still benefit from Foresight Powers & Spiritseers.  May not have Fleet Commanders or Aspect Warriors aboard. Cannot launch boarding actions or H&R attacks and enemies boarding or using H&R against them get a +1 bonus. Attempts to repair criticals are made with half the normal number of dice. Keel weaponry replaced by 4WB@30cmF for Wraithships and 8WB@30cmF for Dragonships.
add: under MSM: Ghostships crippled at 2 hits left
add: under MMS: Ghostships ignore ?Fragile?, ?Dying Race? and ?Eldar Arrogance? rules.
Escorts
Shadowhunters 40 pts
Ordnance
Any capital ship with launch bays may choose to have them launch any mix of Nightwing fighters and Phoenix bombers. Ships with torpedo tubes are armed with Eldar torpedoes. Some Eldar ships have access to Vampire Assault boats or boarding torpedoes.
Attack Rating
Due to the fact that they must defend their Craftworld, Craftworld fleets are more constrained in their tactical choices. Consequently they have an Attack Rating of 3.
Reserves
Craftworld fleets may take Corsair Eldar ships as reserves at a ratio of 3 Craftworld ships of a single type to 1 Corsair of the
same type. If a Hero is included, this ratio becomes 2:1.
edit:
* added spiritseer
* seer council more expensive
* added ghostships MMS/MSM tweak
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Fri Dec 09, 2005 3:06 pm
The list in Fanatic is the Iyanden list.
The elements you have for fleet commanders would be a good basis for a Ulthwe list.
The Construction Worker Space Marines like to paint Yellow and Black Stripes on Everything.  This is for Safety.  They also like to Blow Up Stuff.  This is for Unsafety.  They are very complicated people.  This is why they are very (x2) popular.  ? Sneak Preview of Construction Worker Space Marines
PostPosted: Fri Dec 09, 2005 3:28 pm
I don't think the list in Fanatic is Iyanden, at least not one I like to see, to few Ghostships for example (0-3).
The Fanatic article uses Iyanden fluff but made in my opinion a vanilla CWE list.
Warp Rift
Eldar MMS
PostPosted: Fri Dec 09, 2005 11:05 pm
The Seer council fits better with Ulthwe.  IMO a Spiritseer character that helps out the Ghostships would be a better fit for Iyanden.  The SG fleet is "Iyanden" but not really Iyanden.
You may take one Spiritseer for every 500 points or part thereof.  They must me stationned aboard a Ghostship
.  Each Spiritseer has one reroll that may only be used by the Ghostship the Spiritseer is aboard and it's squadron.  Possibly any Ghostships within 15cm?
Ghostships: a fleet must consist of at least 50% of ghostships
By points, model count, capital ships, something else?
One option to consider is all Wraithships are Ghostships, however all Dragonships are "normal."  This would mean a large number of Ghostships are present and the larger Dragonships lead the fleet (and provide support for the Wraithships/Ghostships in the form of Spiritseers).  Then again, it may be a bit much.
Can Ghostships squadron with "normal" ships?
-Archer
PostPosted: Sat Dec 10, 2005 7:38 am
Good points Archer. I'll include the spiritseer.
But why drop the Seer council? It's limited to 1 in the whole fleet and you need to take an fleet admiral to get to it. For Ulthw? I was planning to drop all restricitions on the Seer Council.
Ah yeah, the 50% rule needs indeed some fleshing out. Still pondering....
Ghostships can't squadron with normal ships. Personally, from an admiral point of view, I wouldn't do it anyway!
Warp Rift
Eldar MMS
PostPosted: Sun Dec 11, 2005 9:24 pm
Seer councils are an Ulthwe thing since they have so many seers (IIRC).  Also, I don't think it's likely for anyone to take multiple seer councils, and chances are they will normally be taken after an admiral is anyways, unless they prove excessively powerful.
IMO decent ghostships and Spiritseers that help offset the downside to Ghostships (like Seers with Wraithguard) is sufficient to distinguish Iyanden from the other craftworlds.  It doesn't go overboard with new material and only adds slightly to the fleet, like the Biel-Tan list.
-Archer
PostPosted: Mon Dec 12, 2005 6:09 am
Okay, points taken. Before I remove them I'll think over them, really since SG included farseers in their supposed to be Iyanden list.
What do you think of the Ghostship rules I presented. They where made by Sigoroth, I removed the parts MMS specific wich gave even more flavour.
Warp Rift
Eldar MMS
PostPosted: Mon Dec 12, 2005 10:40 pm
The ghostships are almost 100% things that make them worse than normal (being able to fail a ghostship's command check and continue with "normal" ships the only good thing).
Since crippling is noted to normally be due to crew casualties and not damage to the ship, perhaps they should benefit from not being crippled until brought down to 2 hits as a bit of an upside?
-Archer
PostPosted: Mon Dec 12, 2005 11:09 pm
Re-reading the ghostships without the MMS touch I see what you mean.
Hope the next Warp Rift is released soon, the Eldar MMS rules will appear in that one.
Basically, they ignore ?Fragile?, ?Dying Race? and ?Eldar Arrogance? rules.
Adding your idea of crippled at 2 hits left would make sense in MSM (Fragile under MMS does the same in a way).
I'll add both Ghostship rules in the near future.
Still in major doubt on the seer council...
Warp Rift
Eldar MMS
