Ground Zero Fighters
 Post subject: Ground Zero Fighters
PostPosted: Fri Aug 26, 2005 6:34 pm
Hi,
I was wondering if anybody had considered using Ground Zero fighters for Gothic?!?!
I thought about buying some stuff for my orks to convert from.. but there isn't any pictures of m?ny of the minis which is quite a letdown!
If you suddenly find that I make any sense.... look out of your window for armageddon!
PostPosted: Sat Aug 27, 2005 1:46 am
yes kbD, I use them exclusively fo all my fleets.
They are cheap and have numerous shapes/sizes available
Tas
PostPosted: Tue Aug 30, 2005 11:44 pm
Using GZG:s fighters is something I've concidered for a long time. However, their lack of picture has thus far put the project on ice. I'm curious, are there any of their ships that might double as a Gothic scale Manta or Barracuda? (The Tau ordinance)
PostPosted: Wed Aug 31, 2005 11:13 am
Yep. Use loads of the things. I have GZG fighters for my Chaos fleet (bombers, fighters and assault ships), my Eldar (bombers and fighters), my Marines (Thunderhawks) and a couple of other fleets. They are excellent minis and the spider flight stand is really worth using. I would recommend that you check GZG fighters out at a con or something, as some of them are less suitable than others. I have got pictures of a few somewhere. I will see if I can find them.
PostPosted: Wed Aug 31, 2005 11:22 am
Oh the joy of playing orks - I can just order a fighter squadron from every faction and mix them up and STILL it'll probably look very orky!  :D
PostPosted: Wed Aug 31, 2005 12:03 pm
Aussies to the rescue! Eureka (GZG Australian distributor), have pics of quite a few of the ships. There are also some pics if you download the GZG catalogue, but the Eureka ones are better:
http://eurekamin.com.au
I do own a fair few, but they are used for my FT fleets, and I just use the normal gothic ones for gothic (perverse, I know :p ), they are a little more expensive, but hey.
Reaversbane (or RB for short...)
