Corsair Eldar vs Tau CPF
 Post subject: Corsair Eldar vs Tau CPF
PostPosted: Fri Oct 23, 2009 8:11 am
scenario : raiders, 750 vs 1500
Eldar MMS v1.9 used with note that all armour is 4+ (instead of 5+ for capital ships, frigates).
Tau CPF: Emissary with grav hooks in place of port/starboard Railguns), getting two Wardens).
I'm the Eldar.
Corsair Eldar
Tuniliev Moonshadow
Eclipse Class Cruiser - Shroud of Frost
3x Aconite Class Frigate - Arith Kian
3x Nightshade Class Destroyer - Bennan Baharr
3x Hemlock Class Destroyer - Oriosa Novar
Tau CPF
1x Emissary + Kor'O and Aun'el
4x Protector Class Cruiser
3x Castellan Class Frigate
2x Castellan Class Frigate
2x Warden Class Destroyer
The Tau fleet deployed facing the sunward (short) table edge.
Formation looked somewhat like this
WW----------------CCCx
-----Prot1-----Prot3
-------------Em
-----Prot2-----Prot4
CC-----------------CCCy
So, a pretty fluffy setup with Emissary plus high ranked officers.
Tau -1ld for 5 turns. (They had good Ld rolls though).
#1
With the Eclipse, Aconites and Hemlocks I enter from the south parking next to the two Castellans, Nightshades enter from North. Nightshades batteries fail to hit Wardens, but its six Torpedoes sear into Protector(1) crippling it in an instance, reduced to 2 hits. The south Protector also becomes crippled and sees its bridge smashed. Bombers remove the two Castellans.
Prot1 tries to disengage but fails. Prot3 & 4 use come to new heading, Emissary dives behind both. CCCx turns with Protectors, CCCy turns south. Shooting  from Wardens destroy a Nightshade (bfi).
#2
The Eclipse reloads and moves behind Protector2. Aconites move north and 2 engage Wardens but fail to hurt them, the other Aconite fails to hurt Protector 1. Hemlocks move quick down the board and unleash Pulsar power plus some batteries on Castellans-y. Six hits later (4 sixes with Pulsars!) all three Castellans are dust. The Eclipse inflicts further hit on Protector 2. Bombers do damage to Protector 1.
Protector 3 & 4 turn further, Emissary in protection. Castellans-x do same. Protector 1 fails disengage, Protector 2 goes on and manages to destroy a Hemlock. The two Wardens move on and destroy an Aconite.
Manta's fail to do damage.
#3
Eclipse, reloads, follows Protector 2 but misses with Pulsars. Bombers fail to damage Protector 1, 2 fighters protective pattern. Nighsthades try to hurt Wardens but cap fighter (overlooked!) removes missiles (dumb action). Hemlocks slip behind Protector2. Aconites move back.
Protectors 3 & 4 turn horizontal to long table edge. Emissary still in wake, directly behind Protector3. Castellans-x turn inward and launch missiles at Eclipse, destroying1 fighter, evading another. Eclipse doesn't brace, missiles inflict 1 hit and critical hit on prow pulsars which are not repaired (ouch). Wardens lock on to Eclipse but roll badly. Protector2 disengages.
#4
Hemlocks move forward down shield on Castellans-x, Aconites destroy 1 of the Castellans. Nightshades launch missiles at Protector3, all 4 torps miss, move on to Emissary and inflict 2 hits, crippling the ship. Eclipse fails reload and fails repair...uh oh.
Protectors 3 & 4 lock on and destroy an Aconite and remaining Nighsthades (2 failed bfi tests on Ld10..). Emissary doesn't disengage.
#5
Hemlocks and Aconite move next to Emissary and destroy the vessel, warp drive implosion and all ships survive...phew-ie. Eclipse bombers inflict a hit on Protector 3, fighters on cap. Eclipse repairs Pulsars.
A pod shot from Castellans is thwarted bu Aconite holofield, nothing else. Manta's too far away.
#6
Remaining Eldar (1 Eclipse, 2 Hemlocks, 1 Aconite) fly away and disengage.
Victory Points
Corsair Eldar: 580 victory points.
Destroyed Emissary + command, 2 crippled Protectors, destroyed Castellan squadrons CC+CCCy.
Tau CPF: 236 victory points.
Destroyed Nightshade squadron, Crippled Aconite squadron.
Conclusion
Interesting game!
The Corsair had a great start, crippling two Protectors and destroying a Castellan squadron. Next turn destroying a whole Castellan squadron with my Hemlocks was good as well. I made some mistakes as sending a torp wave into a cap fighter, should've splitted wave. I was also to eager. Initially I moved Nightshades back, Aconites as well to setup a new run but I forgot that and ditched in melee. Bad choice which costed me entire Nightshade squadron and almost the Aconites.
The Tau were at a real disadvantage, the Protectors only engaged in turn 4 with their weaponry. In turn 4 numbers started to count and Tau started to gain the game back in. My bad thing was I failed to eliminate the two crippled Protectors, alas they didn't hurt me but it would've been more clear if I destroyed them. Tau Manta's had a bad field day overall. Eldar turrets being succesive.
I think if I had stayed on the board for another turn the Tau would've netted it.
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Fri Oct 23, 2009 2:45 pm
My comments (the Tau player involved)
1) Pretty good ld rolls for the capital ships. (ld8 or ld9 including assigning fleet cmdr.
Pretty poor (ld 6 or ld7) for all the escorts except the Wardens. (ld9)
I commented that I'd have a 'snowball's chance in hell' with slow, lumbering Tau vs the agile Eldar getting the 'alpha-strike' on a silver platter.
So I did what a proper Tau would for the Greater Good; group the ships around the Emissary, thus protecting the important Air Caste member travelling in there.
(or in normal-speak; I just made a 'fluffy' set-up expecting to be hammered anyway)
The initial strike was crippling for 2 Cruisers as you'd expect.
The turn after lady luck spitting in the face of Tau was a bit much.
(rolling how many 6-es again? Me failing how many BFI the very same turn? thus obliterating my Castellans?)
In turn 4 I told that I should disengage the crippled Emissary but I'd like to see how the thing works. so I didn't . It wasn't a 'tournament' game anyway.
So take note I ignored common sense to see how the (pricey IMO) ship would fare.
Conclusion:
The scenario is nigh unwinnable for Tau vs Eldar coming from behind.
Perhaps a different (facing all 4 directions) set-up would help.
But that would be rather 'unrealistic' IMO.
A group of ships travelling together but facing different directions???
Then again; it is a game involving ships with alien races..  :grin:
Perhaps i should not care about realism?  :whistle:
My take on Tau: (note; after a mere 2 games!)
Protectors; rather fragile but packing a mean, mean punch as long as you reload.
(but you are doomed if you fail to!)
Emissary: way expensive.
The combo 4 hitpoints/1 shield means "KILL ME FAST FOR EASY VP".
This combined with slow moving and slow turning = certain death.
Castellan; 'feels' a bit pricy but you need some squadrons of these to give you more manoeuvrability.
As with the Protectors; as long as you reload they pack a nasty punch.
Warden; Damn. how I love this ship. The *only* damn ship I do not need to bloody reload with to be effective!
Overall my take on Tau; not enough variation.
With Emissaries not worth it and Wardens limited to the number of Custodians/Emissaries Tau fleets look too similar.
I'd love some consensus on the 'Aeronautica Imperialis' Tau ships and incorporating these into the BFG Tau fleets.
This would give Tau players the option vary with their ships/fleets.
The Wardens should have an option to be bought without Emissaries/Custodian.
A simple "0-1" squadrons of Wardens with a maximum of 5 (or even 3) can be bought at 40 pts each.
Any Wardens you take with custodians/Emissaries can be bought for the 'standard' 30 points.
All things considered; I like Tau. Because the ships are so damn hawt.
But to play with? Meh.
Do not read anything into this
Users browsing this forum: Google [Bot] and 1 guest
