Hammer Kroozers
 Post subject: Hammer Kroozers
PostPosted: Mon May 09, 2005 5:22 pm
Eres a pic of my planz for a Hammer class Battle Kroozer.
My basic idea is this...
1: Take on TerrorShip Kroozer. Cut the dorsal fin off and replace it with engins from a KroolBoy "or scratch build something simular"
2: Take the bottom section of the TerrorShip and cut the launch bays off. Keep the middle bit of this section " the bit u stick ur prog into" intact and glue that the the TerrorShip as normal.
3: Glue the TerrorShip's origanal engines to the bottom setion so now all three engines has a simular setup to a Kroolboy.
4: Cut the kannons off the launch bays, glue the launch bays at the rear "see pic"
5: Beef up the prowl's lower jaw and attact the kannons there.
6: Add a few more turrets to the sides and there u go!
This is how I plan to make my Hammer BattleKroozer. Should give me something thats is between Kroozer and BattleShip in size and look very Orky :thumbs
Hope that makes sence, what u reakon?
Now heres the problem.
Ive read the fluff for the Hammer
http://www.specialist-games.com/battlef....ast.pdf
It states the Hammer is a "Battle Kroozer" where ships such as a KroolBoy are defined as "BattleShips"
In the stats a Hammer is classed as "Kroozer/10" for Type and Hits whilst a KroolBoy is classed as "BattleShip/12"
To me that says the Hammer falls somewhere between Kroozer and BattleShip.
But then its been sudjested that a Hammer is just anuva class of BattleShip "such as the Kroolboy" so should be the same size.
So wats right?
Nuf Said.
PostPosted: Wed May 11, 2005 6:26 pm
Well thanx for the overwhelming responce! :laugh:
Anyway I worked it out and heres my own Ork Ship Guild :D
Nuf Said.
PostPosted: Thu May 12, 2005 8:59 am
Great work Krooza, like the Kroozer but my favourite is still the Gouga, still no claws though :(
PostPosted: Thu May 12, 2005 2:42 pm
Loving the jaw on that BattleKrooza, great conversion!
www.darkrealmminiatures.com
PostPosted: Thu May 12, 2005 5:51 pm
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
The 4 special kroozers with names (Kroolboy, Gorbag'as revenge, slmblasta & Deathdeala) are supposed to be specially good hammer class ships. Actually I think the Slamblasta is one of the worst ships ever designed for BFG, and that any ork fleet of the same points can tear him appart, but that is not the point.
The point is that you got it right:
1) The battleships are very scarce, so scarce that they are recongnized by individual names. Very few ork vessels attain such status at all since they cannot grow/scavenge other ships enough to be built to such level of profficiency. There are other ork BBs out there for sure, but those 4 were the ones spotted in the armageddon war. Ork battleships are created by improving previous designs. I would say that all those battleships are simply hammers with extra armour and weaponry added to them, in the same way that hammers arwe mostly regular ork cruisers that got improvements themselves. Ork build techniques are based on stacking more and more stuff on top of the previous stuff, so there you go :)
2) Hammers are much more powerful than the regular ork designs of the kill & terror variants. Still, they are not powerful enough to come toe to toe with an imperial battleship, so they are rated in between. In that sense they are more similar to the imperial grand cruisers or battle cruisers than battleships. Still, they pack quite some punch and are one of my favourite ships out there. I think they are what you would call "ork essence": loads of all kinds of weaponry and stright for the enemy's head!! :D
I really like your designs. Extremely coll stuff!! :laugh: Heep the good work up krooza :cool:
Regards,
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Thu May 12, 2005 10:47 pm
Thanx.
This is how Im planning to build my fleet...
Warlord 1
1 Kroolboy with 2 Kroozers and 10 Escorts.
Warlord 2
1 Hammer with 2 Kroozers and 10 Escorts.
Warlord 3
2 Gouga with 2 Squadrons of 10 Brute Rams each
My Hammer can be used as a Hammer or a DefDeala as it uses the same weapons
I plan to make a huge Dreadnought too... just coz I like em
Nuf Said.
PostPosted: Fri May 13, 2005 1:52 pm
Doesn't look bad at all! :) Tell us how it goes.
With orks remember that you are basically an ork. That means that shooting things is really kewl, but you prefer to use a large piece of heavy metal to break your enemy skulls. On this issue, read "boarding actions and ramming since you auto-AAF", or even better, both :D
Quote (kr00za @ 12 2005 May,22:47)
On the dreadnought thing, I love the idea and given your modelling skills I think it will look fantastic. Kudos to you. I would suggest using the hulk rules for it, even if you can design rules for it yourself as well. If you make it cost the same as a hulk (650-ish points IIRC) you can have a massive dreadnought already, with the advantage that if your opponent does not agree to play against your homebrew rules you simply say "ok, no prblem: it is a hulk" andyou can use it anyway! :D
Do you plan on building roks or a regular hulk as well? I would really like to see what you can model for those.
Health and sixes,
Xavi
PostPosted: Fri May 13, 2005 5:58 pm
Cheers :;):
Well eres a preview of my Drednort :D
Check out the drydoc for some pics of my rokz :;):
Nuf Said.
