Chaos Light Cruiser
 Post subject: Chaos Light Cruiser
PostPosted: Sat Sep 04, 2004 2:47 am
I've got acouple of the old Ironclad BB from Space Fleet :)
I've made them into Chaos LC's, see what you think.  Fluff to follow  :p
Ironclad Light Cruiser
Cost - 125points
Hits - 6
Sheilds - 2
Turrets - 2
Turns - 90%
Speed - 30cm
Armour - 5+
PWB - str 6 - 30cm left only
SWB - str 6 - 30cm right only
Prow lance - str 4 - 30cm front only.
I was trying to keep roughly to the old concept from space fleet, hence the Lance being front only.  Not to sure about the speed, str of lance & range of lance.
Let me know what you think.
:D
I have a cunning plan...
PostPosted: Sat Sep 04, 2004 4:20 am
Is there any way you can show a picture of the ship.  I'm not familar with the pre Gothic ships so I don't know how it compares in size to the Dauntless.  Is it bigger or smaller?
I think using the Dauntless stats would be good for a Chaos light cruiser.  You won't have any one questioning the respective point value of the ship. Based on the stats you have given it appears that this model has a layout much like the Dauntless so it would work.
As it ships stats stand now it is undervalued.  It is a far superior ship class to the Dauntless because of it's increased speed, shields, turrets, lance and Weapon battery strength.  The only thing it doesn't have is the "All ahead Full" special rule.  You get all this for 15 points. A good investment in my mind.
It's hard to give my recommendation without seeing the ship.
Assuming it is the same size as a Dauntless, I recommend. Droping the shields and turrets to 1.  Make the weapon batterries STR 4 each.  Make the Lance battery stats 45cm STR 2 front only.  It fits chaos to have longer range lances.
Thanks for sharing and I hope I helped.
Take Care
PostPosted: Sat Sep 04, 2004 2:47 pm
Heres a link; scroll down a little to see the Ironclad. http://www.solegends.com/citsfleet/imperial.htm
www.darkrealmminiatures.com
PostPosted: Sun Sep 05, 2004 1:26 am
Thanks for the pics Stormy but it's still hard to judge relative size.
PostPosted: Sun Sep 05, 2004 3:21 pm
The Gothic battleship is 8cm long, so going by my estimation, the Ironclad is approximatly 5.5cm long...
