Battlefleet Gothic mag 18 is here
 Post subject: Battlefleet Gothic mag 18 is here
PostPosted: Fri Jan 23, 2004 6:20 pm
Well the penultimate mag is here before it gets swallowed up by the hungry ma of the new Fanatic magazine.
*** Slight spoilers ***
News/Incoming - Nothing much new, mostly focused on the upcoming transfer of power. Did say all experimental rules are now to be featured in a BFG vault (a la Epic), not the magazine due to time lag issues.
Elaysion Crusade - Slightly loose campaign (Imperial v Chaos) for use with the last issues vagaries of war article.
Eye of Terror - Roundup with a BFG slant. Basically the Chaos fleets had massive local superiority early in the war, but when the huge Imperial Navy warmachine swung into top gear it scattered all before it. The gate held due in a large part to the Navy ( :) !), but more of Abaddon's followers got through than ever before and this isn't good for the eternally beset Imperium [It would be nice for mankind to go on the offensive for a change, if only on a limited front. Damocles Crusade mark II? Those Tau had it too easy in the last war!]. Includes results beakdown for the statistically inclined.
Tyranid Hive Fleets (and Vanguard fleets) - These are full official rules. They were however marred by the lack of proof reading. The Vanguard Droeship has the same 14 line intro as the Kraken (cut 'n' paste error here I suspect) and in the fleey list section it manages to miss up the start of escort drone section, including its basic points cost (20 points??) :L
Jackhammer
