Combining marks of chaos
 Post subject: Combining marks of chaos
PostPosted: Sat Nov 08, 2003 2:01 pm
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
Hello there!
Today I tought about a completely unfluffy but good combo of marks IMO: Nurgle + Khorne.
If Inread that correctly mark of nurgle prevents you being boarded and gives you +1 hit points while mark of Khorne doubles your hit points modifier in boarding actions.
So, if we take that into consideration a mark of nurgle is effectively giving youi a +2 to your hit point calculation in boarding actions. Is that correct? Seems a good combnination to me.... Not cheap, buit if yu are taking thr mark of Nurgle the extra 20 points might be handy for that much extra punch in assaults. Am I correct?
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Wed Nov 12, 2003 2:20 pm
I'm unsure.  Usually when you have situations like this, you double values before adding individual points.
For example -> Eldar Striking Scorpian Exarch in 40K.  Equiped with a powerfist and has the power crushing blow.
In this example you are required to double your strength first, before adding the crushing blow bonus for a total of S9.
I know this is for a different games system, but GW usually stick to the same principles.  So I would say, double the normal ships boarding value and then add the nurgle bonus.
However, I would talk to your opponent before the game to make sure there is no confusion.
PostPosted: Wed Nov 12, 2003 3:12 pm
Hmm... you could be right.... I posted the question in the BFG yahoo list as well. Let's see what they think about it :)
Cheers mate.
Health and a lot of sixes,
Xavi
PostPosted: Thu Nov 13, 2003 5:55 pm
I am with Shadow Hunter on this. If there are two interpretations of an upgrade combination, you should usually take the least effective.
Also, if I remember correctly, Nurgle marks stop you being boarded, but you can be boarded as the result of a failed boarding action that you initiated.
