Fra'al
 Post subject: Fra'al
PostPosted: Tue Jun 10, 2003 12:22 am
What the feth is a Fra'al?
I have a cunning plan...
PostPosted: Tue Jun 10, 2003 1:21 am
They were some kind of alien race that BFG magazine featured in an earlier issue. Their ships were made from parts of the first Necron line.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Jun 10, 2003 9:19 am
..I believe they also have passing mentions in various other bits of background to the Fra'al, I think there are some in the 40k 3rd Ed rulebook IIRC... :l
They were described as being piritical raiders I think, but were not developed much more than that...
www.darkrealmminiatures.com
PostPosted: Tue Jun 10, 2003 2:04 pm
Which is a shame.  They have some interesting technology.  It'd be interesting to see where its come from.  Whether they developed it, or it was stolen from others.
PostPosted: Tue Jun 10, 2003 2:58 pm
ShadowHunter,
Which is a shame. They have some interesting technology. It'd be interesting to see where its come from.  Whether they developed it, or it was stolen from others. - ShadowHunter
What kind of technology do the Fraal have?
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Jun 10, 2003 3:40 pm
Didn't the cruiser have something called a Ether Lance?
If I have remembered correctly, and it has, then that is the technology that is of an interest.
It sounds like it taps into the warp for its power in a similar manner to a wraithcannon.  Now, the Eldar are really the only race who uses that technology on a regular basis.  So, did they steal it from them?  Develop it themselves?  Or was given the info by the OO in the same way the Eldar were?  How old a race are the Fra'al?  Does anyone know?
PostPosted: Thu Jun 12, 2003 7:48 pm
O.k, what's the stats? & where can I buy one?
PostPosted: Fri Jun 13, 2003 12:01 am
Campsie,
O.K, what're their stats? And where can I buy one?
The Fraal ships were made using pieces from the original Necron line.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri Jun 13, 2003 4:23 pm
...And the stats originally appeared in Planet Killer IIRC, which I don't have- sorry... :O
PostPosted: Fri Jun 13, 2003 8:01 pm
From Planet Killer
Fra'al Battlecruiser
Battleship/8 20cm 45 3shields 5+ 3 turrets
Prow lances 45cm firepower 2 arc Front
Dorsal lances 45cm    "        3 arc front/left/right
Ether cannon 60cm 2/special   arc front
no points cost (special scenarios only) threat to all!
Ether cannon
When firing the ether cannon roll d6 for each point of strength .
Roll less or equal to shield strength of target vessel = 1 point of hull damage ,the shields remain intact.
Roll higher =1 point of hull damage ,the target vessels shields are also overloaded -all are knocked down,place an approiate no of blast markers.
aganist Eldar, who have no shields the Ether cannon needs a 5+ to hit and will do one point of damage if it hits. The holo fields do not save aganist this, as the attack already takes the holo field into account. If the eldar craft has no holo fields the roll to hit is a 3+.
The LOCK-ON specil order has no effect on Ether cannon firing.
Fra'al regeneration
Can repair critical damage as normal.
In addition the may channel power to repair hull damage. Simply roll the dice normally for hull damage repairs, and replace one point of hull damage on the roll of a six.
Disengagement
Fra'al may disengage at any time without the need to roll.
If a Fra,al battlecruiser ends the turn with 2 or less hull damage points it will immediatly disengage.
Expert Commanders
Always test aganist leadership of 9.
Fluff by Che Webster
The Fra,al deploy battlecruisers into deep space and use them to protect their worlds from orbit, usually single ships or in pairs to raid convoys or systems. No one knows why they fight this way, what technolgy they use or who they are.
the most significant threat comes from their ether cannon which firs e pulsed engry beam at a target ship. The ether beam corrodes the hull of the target ignoring shields.
And so-on
I hope you find this of use...I have a copy of the magazine in question and would gladly share photocopies with you but copyright law makes this illegal and so I cannot do that, sorry
PostPosted: Wed Jun 18, 2003 9:24 pm
Hi mate,
   Have you made one of these cruiser?  I'd be willing to buy one off of anyone if the've made one...  :L
PostPosted: Thu Jun 19, 2003 9:53 pm
:( Unfortunatly not!
I think that they were used for a BFG event at Warhammer world as a random event, and the rules put in the first mag as a space filler without actual building instructions only a few photos.
The model appears to have parts from the Blackstone fortress, the Imperial battleship and the old metal Necron destroyer from the first range.
Sorry I cannot help you further, although the model would/should be within my abilties to construct, I doubt that it would be worthwhile by the time that the parts were obtained (from mail order) and constructed and painted.
I am off work now for a few days though and will look into it and try to get you a precise figure.
Regards...
PostPosted: Thu Jun 19, 2003 10:36 pm
A local player made some, but that's only because his father is (and now was) a GW dealer so he could get the pieces cheaply.
They're not worth making at GW bitz costs unless you just... HAVE TO HAVE THEM!
They're neat, but I still have Necrons to fool around with.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Sat Jun 21, 2003 8:49 pm
Agreed,plus the nasty postage charges too!!!
