Post new topic Reply to topic  [ 262 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18  Next
Rogue Trader Fleet Guide & Analysis
 Post subject: Rogue Trader Fleet Guide & Analysis
PostPosted: Sun Dec 09, 2007 7:29 pm
Wow, a playtester! i Thought we were only two...
I you don't mind, due to the extremely low frequency of postig, post yor BR here in this thread. That way it will not disappear as it has happened several times before.
BTW, i really need to get my rulebook back to play BFG again. Lately it's all E:A and Armies of Arcana.
"It would be most ilogical if i let you kick my ass"
-Spork, son of Spoon son of Fork
PostPosted: Mon Dec 10, 2007 1:34 am
Here's the first playtest, the second will follow. Yannic will post the detailed fleet lists soon. I've tried not to put in too many subjective stuff, just sticking to the facts. Discussion will follow I suppose :)
Rogue Trader Playtest 1 (750pts, no scenario, 4 turns)
Sides: Rogue Traders (Galleon, Merchantman, 2x Lorcha, 2x Hellebore) vs. Chaos (Hades, Carnage, Devastation, 3x Infidel) (Chaos moves first)
The first turn is spent by both forces moving towards each other. The chaos fleet sets off on a flanking move intending to maximize its range advantage by making a large arc around the left flank of the Traders. The Traders move forward in a straight line.
The second turn the chaos fleet moves into range (@60cm) and fires all its available weapons (Carnage and Hades on Lock on, Devastation) on the nearest Lorcha, crippling it and inflicting a port weapons damaged crit. The Devastation also launches two waves of two bombers.
In the Traders? second turn the Trade Galleon and Merchantman let loose at a squadron of chaos infidels which wandered within 30cm of them, destroying one and shooting down a shield on another. The Eldar Hellebores position themselves behind the chaos fleet, but cannot take a shot yet.
In the third turn the main chaos fleet continues in its circular movement, now coming within 30cm of the Traders? fleet. The full force (LO Carnage, LO Hades, Devastation and the two remaining infidels) attacks the closest ship, being the Merchantman, crippling it. The Rogue Trader fleet fails all BFI rolls.
In the Traders? part of the turn the Galleon uses its Displacement drive to move behind the Chaos fleet. The Displacement Drive gives quite interesting strategic options to a slow ship like the Galleon. The Hellebores, who have by now positioned themselves up the tailgate of the Devastation, and the Trade Galleon mage to shoot down 2 shields on the chaos carrier. The Merchantman?s fire is ineffective.
In turn 4 the chaos fleet moves in for the kill, but doesn?t do a lot of damage only bringing down two shields on the merchantman with the Devastation, Hades and Carnage at 45cm. The two bomber waves launched in turn 2 finally find their mark, completely carpet-bombing a Lorcha out of existence (7 hits made on a Lorcha with only 2hp left). The included picture shows the battle at this point.
In the equalizing turn, the Trade Galleon once more uses its Displacement Drive to get into the rear arc of the Devastation and together with the Hellebores manages two make two hits on the Devastation which has braced for impact (1 save made, 2 failed). The remaining Lorcha takes out one more infidel escort.
Final result: Chaos 102,5 VP, Rogue Traders 0 (one more infidel killed would have meant victory with 120VP for the Trader)
PostPosted: Mon Dec 10, 2007 1:15 pm
Rogue Trader Playtest 2 (750pts, no scenario, 4 turns)
Sides: Rogue Traders (Galleon, 3x Lorcha, 4x Brigantine) vs. Imperial (2x Lunar, Mars, 3x Cobra) (Trader moves first)
The first turn the Rogue Trader fleet moves forward with the Galleon on AAF and the rest making normal movement.
The Imperial fleet fires a LO nova cannon, however fails to hit and just knocks down a shield on a Lorcha. 3x6 torpedoes are launched in a wide spread which end up approximately 25cm from the Rogue Trader fleet. A wave of 3 bombers and 1 fighter is launched.
In turn 2 the Rogue Trader fleet manages to dodge the torpedo salvo but is split in two as a result with the Brigantines evading to port and the main force turning to starboard. The Galleon launches a 4-strong fighter wave which neutralizes the imperial bomber wave.
In the Imperial turn the nova cannon fires once again at the Lorcha?s and once again fails to score a direct hit, instead knocking down a shield. The Lunars manage to come within 30cm of the Trade Galleon and knock down its 3 shields and score a hit. The dual lances on the Mars score a single shield hit on the Brigantine squadron.
In turn 3 The Rogue Trader fleet manages to get up close and personal with a Lunar unloading a total of 20WB@15cm and 28WB@30cm on it. The Lunar copes well and receives only 2 shields down and 2 hits. 4 single assault boats from the reloaded Galleon make short work of the Cobra squadron, destroying all escorts.
In the Imperial turn the Lunars unload on the Brigantines (which brace) at point black range (15cm), killing one Brigantine and knocking a shield down on a second. The Mars fires a broadside at 30cm into the Trade Galleon but only makes a single shield hit.
In turn 4 a total of 28WB from the Galleon and Lorcha?s hit on the Mars, which failed to brace, crippling it. 5WB from the remaining Brigs take down a shield on a Lunar.
In the last Imperial turn the combined fire of Mars and Lunars (mitigated by the mars being crippled) takes down 3 shields on a Lorcha and the Galleon. The attached picture shows the battle at this point.
Final Score: Rogue Traders 157,5VP, Imperial 0VP
PostPosted: Mon Dec 10, 2007 1:17 pm
Yannic will post detailed fleet lists including upgrades for the Traders. We also made quite a few changes as a result of playtesting in Rogue Trader points which will need to be approved/ridiculed :)
PostPosted: Mon Dec 10, 2007 2:45 pm
Detailed fleet lists will come hopefully tomorrow, as I forgot to transfer them to my laptop. I'll also upload the Rogue Trader Fleet list Version 4 with all our changes
PostPosted: Mon Dec 17, 2007 7:47 am
Curious awaitin....
, battles look good.
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Mon Dec 17, 2007 12:17 pm
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
Looks good :) Awaiting the document :cool:
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Tue Dec 18, 2007 12:16 pm
sorry guys, I keep forgetting to transfer the files to my laptop ( I still don't have internet at home :( )
PostPosted: Thu Dec 20, 2007 3:25 pm
Hi guys,
attached are the RT fleetlist version 4 with all our changes and the first playtest fleetlist. I've seem to have deleted the other playtest list, but I'll try to find the hardcopy version
damn for won't let me attach an excel file. I'll try to convert it to word asap, but now I've got to work
cheers
PostPosted: Thu Dec 27, 2007 10:42 am
Isn't that just the rules list.
We were interested in the used test fleets as well!
Warp Rift
Eldar MMS
PostPosted: Sat Jan 12, 2008 3:07 pm
At this pace this fleet is going to be published when GW goes bankrupt!!!
I suppose now it's time to retrieve my BFG rulebook and test the rules a little bit more (although i thought they were sufficiently balanced right now)
PostPosted: Sun Jan 13, 2008 1:58 pm
sorry guys! But the good news is I've got my internet working at home finally!
I'll sort out the fleetlists tonight. I thought our release deadline was sometime in may? ( horizon?)
Haven't had the time to do another playtest, since college is once again interfering with exams ( end of january).
PostPosted: Mon Jan 14, 2008 10:34 pm
Hi guys,
This is the first playtest fleetlist! enjoy
I'll try to recover the second one ;)
cheers,
Yannic
PostPosted: Tue Jan 15, 2008 2:11 pm
lol, Eldar MMS. Good job :)
March is Warp Rift 17
May is Warp Rift 18
Warp Rift
Eldar MMS
PostPosted: Tue Jan 15, 2008 6:28 pm
Yups, really like the MMS rules ( I've allmost finished my corsair fleet so I'll post some pictures pretty soon I hope)
