Eldar Warp Hunter - weapons?
 Post subject: Eldar Warp Hunter - weapons?
PostPosted: Tue Oct 13, 2009 9:18 pm
Hi all, I recently bought a squadron of Eldar Warp Hunters - I know they were armed with the warp cannon/d-cannon, but did they have any other weapons?
If anyone could advise me or even scan me the original datacard, I'd be forever in your debt!
PostPosted: Tue Oct 13, 2009 11:05 pm
In Epic:Armageddon, the Warp Hunter is now for all intents and purposes, the Cobra, with the following statistics.
Code Sample:
Cobra   WE   25cm   5+   6+   5+
Cobra D-Cannon*          30cm      2BP, TK (D3+1), FxF
Shuriken Cannon          30cm      AP5+
Eldar Missile Launcher   45cm      AP5+/AT6+/AA6+
DC 3, Skimmer, Reinforced Armour
Critical Hit Effect: The Cobra’s gravitic drives implode, sucking nearby troops into an energy maelstrom. The Cobra is destroyed and any models within 5cm of the
model suffer one hit on a roll of 6.
* Cobra D-Cannon: This weapon counts as having the 'Ignore Cover' special ability against war engine class targets
Not being familiar with Epic 40K, I can't help much with conversions back, but above, it's got a Shuriken Cannon and the Eldar Missile Launcher. The Shuriken Cannon in E:A is the same as that used on the Tempest (Scorpion), and the Eldar Missile Launcher the same as that on the Revenant Scout Titans. I can't vouch for any other changes that may have been made between editions. Someone with more familiarity will have to help out there.
Morgan Vening
 Post subject: Re: Eldar Warp Hunter - weapons?
PostPosted: Thu Jan 15, 2015 4:46 pm
I'd use following stats in Epic 40,000 3rd edition.
Warp Hunter 41 Points
Move 30cm
Range 45cm
2 x anti-tank
Assault 1
Armour 5+
Skimmer
Epic 40,000: Exodites, Necrons, Dark Eldar, Sisters of Battle, Tau
BLOG: Epic 40,000
BLOG: Warmaster
Toco's Mod: Allied HeroQuest
PostPosted: Fri Jan 16, 2015 7:53 pm
Move 30cm
Range 45cm
2 x anti-tank
Assault 1
Armour 5+
Skimmer
I am pretty sure the Cobra is the Epic 40k equivalent to the Warp Hunter, as the Scorpion is to the Tempest. ;)
PostPosted: Mon Jan 19, 2015 9:44 am
Ah, interesting too. And more acceptable. I'll have a look into this.
Edit: You're right. The Warp Hunter doesn't need its own stats in Epic 40,000. It can use the Cobra war engine stats. Thnx for pointing that out.
BLOG: Epic 40,000
BLOG: Warmaster
