Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Helge's Eldar ToEG 2012
 Post subject: Re: Helge's Eldar ToEG 2012
PostPosted: Tue Apr 03, 2012 9:15 am
Excellent Helge
I am always keen on an update of your thread
PostPosted: Fri Apr 06, 2012 4:30 am
More bulk troops. Starting on the vehicles now (all in bulk... probably a mistake).
My blog and armies: http://wargamingworkshop.wordpress.com
PostPosted: Sat Apr 07, 2012 2:58 pm
zoglug wrote:
Can i ask, how do you do the bases to hide the flat part of the epic models? Or do you chop them off at the feet and glue them that way?
Basing instructions are on this page: http://wargamingworkshop.wordpress.com/ ... rmageddon/
Basically the same for all my Epic armies. At this scale, consistent and realistic bases are probably as important as the models (if not more). So I try to do them nicely.
PostPosted: Thu Apr 12, 2012 5:00 am
With the dreaded Squats completed, it's time to go full steam ahead with the Eldar. I am doing the vehicles in bulk so here is the horde of purple:
There is actually more work here than the photo shows, mostly because the underside of each vehicle is already painted (so that I can glue them onto their bases). Topside and detailing is next.
PostPosted: Thu Apr 12, 2012 6:54 am
Did you wash the models??? And with what?
PostPosted: Thu Apr 12, 2012 9:35 am
looking good so far. That is an inspiring amount of purple painted how long did that take?
PostPosted: Thu Apr 12, 2012 10:08 am
Ditto on the purple - that's a lot of the stuff applied. Do you actually basecoat with the base already painted? That's scary! Looking good.
Back from oblivion (again)?
PostPosted: Thu Apr 12, 2012 12:29 pm
Are you trying to complete your TOEG in one month just to make the rest of us look bad? ;)
Army projects:
Iyanden Eldar - complete
Hive Fleet Scorpio - complete
Ulthwé Eldar - complete
PostPosted: Thu Apr 12, 2012 2:06 pm
Wow- that is an amazing amount of painted Eldar. This will be another stunning army.
You did realise that TOEG is only 500 points per month? Not complete army?
Great stuff
James
My Epic trades list
PostPosted: Fri Apr 13, 2012 1:36 am
I am a mass production kind of a guy - what can I say.
My painting process for this was as follows:
0. Prep model (flash removed, drill out engines, etc.)
1. Spraypaint black (both sides, models in parts and removed from base)
2. Airbrush a 1:1 mix of Liche Purple and Skull White (both sides)
3. Wash both sides Leviathan Purple twice (let dry in between, do one side at a time, use the brush to dab away excess wash on the flat surfaces)
4. Paint underside detail Dheneb Stone, then Devlan Mud Wash, then Skull White hightlights/wetbrush
5. Paint underside engines and other detail Vallejo Brass, then Devlan Mud Wash
6. Glue everything onto the skimmer base (my regular bases with a steel wire post).
At this point I can paint the top while on the base (for easier handling). The underside work is not visible on the overhead picture but you can see it on the tabletop.
I will now manually highlight some of the panels on top and then detail. The Falcon with the black turret zone is my prototype model (3rd in the second row from the bottom). The models are actually higher contrast and show more shading on the purple already. My flash just wiped some of that out. Incidental, the purple on the guardians is exactly the same but there the pic makes it look darker... (same painting steps as well).
PostPosted: Sun Apr 15, 2012 4:02 am
I need some inspiration. I finished the first test vehicles:
The models are more contrasty in real life (flash + bad lighting conditions). I am looking for inspirations for the cockpit windows. Options would be:
Blue like the gems
Green (I use a heavily shaded down Scorpion Green effect for the energy/prism areas on some vehicles)
Shiny Black
Something else (ideas?)
PostPosted: Sun Apr 15, 2012 4:18 am
Blue, but maybe a bit darker than the gems.
PostPosted: Sun Apr 15, 2012 7:16 am
My vote's for shiny black.
Awesome work here, love a nicely done mass prodution run!
PostPosted: Sun Apr 15, 2012 8:08 am
If you like contrast, bright yellow with a flesh or chestnut wash.
